HDD or NVME VPS? We've got you covered! The plan you want most at €10/year.
1235711
  • @c1vhosting said:
    Hi,
    we are working on improving IO speeds on the HDD node.
    Thanks for your patience.
    but can we get boot/reinstall done before the IO improving?
  • @seoky said:
    @c1vhosting said:
    Hi,
    We will need to manually reboot all VMs on POM2 to apply some disk IO adjustments. If your service is having an issue right now, please open a ticket and send me the ticket number.
    C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
  • edited August 25
    @c1vhosting said:
    @seoky said:
    @c1vhosting said:
    Hi,
    "#C1V_1094270_TCUSID"
    After reinstall it just stuck in "The process of rebuilding a VM is in progress. Please wait." for two days
    Thanked by (1)c1vhosting
  • @seoky said:
    @c1vhosting said:
    @seoky said:
    @c1vhosting said:
    Hi,
    Whenever in doubt, please refer to performance advisory
    As mentioned in OP, this offer has struck has a balance between low cost and performance.
    And do not forget the part -- where is this Data center housed?
    @dev_vps said:
    @seoky said:
    @c1vhosting said:
    @seoky said:
    @c1vhosting said:
    Hi,
    what data center?
  • HDD PLAN was sold out...
    dont worry it will be back real soon
  • edited August 25
    @bliss said:
    @Ahui said:
    Here are a few suggestions for you
    1. Add more nodes
    2. Replace AMD EPYC CPU
    3. Low cost VPS prohibits installation of Windows
    4. The number of VPS for each node should be controlled within 100
    That's ridonkulous. Accordingly, here is only one piece of advice for you:
    Quadruple your budget for your 'suggestions'.
    If C1V really did as you suggested, the price of the VPS would be unacceptable.
    I can't even find your similar products during Black Friday, nice wish though.
    Just posted YABS for $12/year VPS (promo price got in May 2024)
    https://lowendspirit.com/discussion/comment/184398/#Comment_184398
    Strong enough to run even Windows Server 2022 OS.
    Need more examples?
    most likely new orders suspended until Disk IOPS is "tweaked".
  • edited August 25
    @dev_vps said: Just posted YABS for $12/year VPS (promo price got in May 2024)
    Need more examples?
    Your comparison is obviously inappropriate because of great difference in disk size: 20 GB vs 140 GB, not to mention your unknown traffic. I could do the same thing by referring to an OVH's offer of "1 core, 2 GB, 20 GB nvme, unlimited traffic @ 100 Mbps" for $0.97 monthly to claim your VPS is not good enough, but I won't do that, it's just inappropriate to compare.
    My point here is I think C1V's offer is worth of the price, that's all. And I would advise everyone to pay with PayPal in case of early dead-pool which has happened many times to other providers here.
    By the way, may I know the name of the provider of your YABS so that ...
  • edited August 25
    Need more examples?
    Your comparison is obviously inappropriate because of great difference in disk size: 20 GB vs 140 GB, not to mention your unknown traffic. I could do the same thing by referring to an OVH's offer of "1 core, 2 GB, 20 GB nvme, unlimited traffic @ 100 Mbps" ….
    I am yet to find any other vps that so consistent download rate of 1 gig … irrespective of location
    and cpu vCore is Ryzen 7900
    c1v vps has 2 gb memory, but one is expected to use only 50% of that. 140gb is only plus factor for c1v “on paper” as the vps is competing with 🐢 on speed.
    other details you can find at looking at YABS I have posted.
  • edited August 25
    @bliss
    Another example — cheaper than c1v
    This one has 10gig data port too
    https://lowendspirit.com/discussion/comment/184231/#Comment_184231
  • edited August 25
    @dev_vps said: download rate of 1 gig …
    Well, how much traffic is given monthly then? Most providers offer 1 or 2 TB then suspend VPS or reduce speed until next month.
    @dev_vps said: and cpu vCore is Ryzen 7900x
    If you think CPU performance is important, then choose what you like. I don't think C1V is stable enough to run important software, thus I only run some P2P, backup, private VPN on it, which consume less than 0.50 CPU all together (0.15 or less on other powerful VPS). A CPU of 200 GB5 points is enough.
    @dev_vps said: Another example — cheaper than c1v
    Oh, that's very tempting. Can you kindly disclose the offer link so that I can buy it. Thank you.
    5 TB per month … my usage is about half of that
    If you think CPU performance is important, then choose what you like. I don't think C1V is stable enough to run important software, thus I only run some P2P, backup, private VPN on it, which consume less than 0.50 CPU all together. A CPU of 200 GB5 points is enough.
    as you have mentioned… c1v has pretty limited use case. And I find other promo offers much better value
    I use c1v for testing how database engine recovers from abrupt shutdown and no other provider is better than c1v vps.
    I do not plan to renew c1v vps.
    PS — there is a xyz days of notice required to cancel such high quality vps. Otherwise c1v rewards with renewal.
  • @dev_vps can you disclose the offer links of your performant YABS VPS which are very tempting.
    @dev_vps said: PS — there is a xyz days of notice required to cancel such high quality vps. Otherwise c1v rewards with renewal.
    I don't understand the above sentences. Isn't one simple click on 'Cancel when due' enough to cancel the service? Or just don't pay the invoice to cancel a service? Which provider are you referring to?
    Read c1v terms and conditions.
    https://lowendspirit.com/discussion/6440/important-clarification-cancellation-process-at-c1v-hosting
    Thanked by (1)bliss
  • edited August 25
    We got a mole in the hole! You gotta post those pictures somewhere sometime!
    Forget about popcorns, this is a fireworks event!
  • @dev_vps can you disclose the offer links of your performant YABS VPS. It's boring to share a wonderful VPS without a purchase link.
  • edited August 25
    @foxone Thank you for the link. I think the cancellation procedure is very inconvenient. Customers should be careful about that.
    Edit: After browsing the control panel of C1V, I found it has no differences between most providers in cancellation process: just click on the button of "Request Cancellation".
  • another day .... another VM restart
    c1v vps running Windows 11 Enterprise OS
  • edited August 25
    what should I install next OS on c1v VPS?
    .... let me try Oracle Linux OS ... see if it can be installed
    Update
    Oracle Linux 9.4 installed on VPS
  • my two(2) 400g storage node has been down since.....
    Refer to Performance Advisory
    Please open a ticket and send me ticket number.
    Update
    Uptime     : 0 days, 0 hours, 13 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz
    CPU cores  : 2 @ 2596.990 MHz
    RAM        : 7.6 GiB
    Swap       : 0.0 KiB
    Disk       : 79.9 GiB
    Distro     : Oracle Linux Server 9.4
    Kernel     : 5.15.0-206.153.7.el9uek.x86_64
    ISP        : Cinzia Tocci trading as C1V
    ASN        : AS212271 Cinzia Tocci trading as C1V
    Host       : C1V Hosting
    Country    : Italy
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
    Read       | 79.44 MB/s   (19.8k) | 707.35 MB/s  (11.0k)
    Write      | 79.65 MB/s   (19.9k) | 711.07 MB/s  (11.1k)
    Total      | 159.09 MB/s  (39.7k) | 1.41 GB/s    (22.1k)
    Read       | 1.49 GB/s     (2.9k) | 1.54 GB/s     (1.5k)
    Write      | 1.57 GB/s     (3.0k) | 1.64 GB/s     (1.6k)
    Total      | 3.07 GB/s     (6.0k) | 3.19 GB/s     (3.1k)
  • @c1vhosting
     Speedtest.net
     Location         Latency     Loss    DL Speed       UP Speed       Server
     Nearest          20.37 ms    0.0%    1211.29 Mbps   565.52 Mbps    Uniconnect - Rome
     Houston, TX      149.05 ms   0.0%    1088.12 Mbps   371.06 Mbps    Ezee Fiber - Houston, TX
     Chicago, IL      120.85 ms   0.0%    1368.67 Mbps   272.05 Mbps    Enzu.com - Chicago, IL
     Miami, US        139.18 ms   N/A     1236.35 Mbps   313.16 Mbps    Dish Wireless - Miami, FL
     New York, NY     114.06 ms   0.0%    1259.03 Mbps   265.31 Mbps    Surfshark Ltd - New York, NY
     Miami, FL        129.51 ms   0.0%    1606.76 Mbps   304.89 Mbps    ReliableSite Hosting - Miami, FL
     Spokane, WA      169.34 ms   0.0%     902.60 Mbps   249.79 Mbps    Crunchbits - Spokane, WA
     Seattle, WA      177.93 ms   0.0%    1024.14 Mbps   302.30 Mbps    Misaka Network, Inc. - Seattle, WA
     San Jose, CA     167.67 ms   0.0%    912.56 Mbps    294.24 Mbps    Misaka Network, Inc. - San Jose, CA
     London, UK       34.76 ms    0.0%    1526.58 Mbps   541.56 Mbps    VeloxServ Communications - London
     Amsterdam, NL    38.08 ms    0.0%    1680.41 Mbps   430.51 Mbps    31173 Services AB - Amsterdam
     Paris, FR        32.37 ms    N/A     1394.39 Mbps   503.85 Mbps    Axione - Paris
     Frankfurt, DE    24.16 ms    0.0%    1513.99 Mbps   590.19 Mbps    Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       44.51 ms    0.0%    1724.87 Mbps   394.13 Mbps    Play - Warszawa
     Bucharest, RO    45.29 ms    0.0%    1238.89 Mbps   439.66 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Chennai, IN      166.94 ms   N/A     1648.01 Mbps   295.31 Mbps    Jio - Chennai
     Mumbai, IN       131.45 ms   0.0%    1573.24 Mbps   293.54 Mbps    i3D.net - Mumbai
     Mumbai, MH       137.42 ms   N/A     1683.78 Mbps   288.17 Mbps    Jio - Mumbai
     Delhi, IN        162.65 ms   0.0%    1333.86 Mbps   304.22 Mbps    Tata Play Fiber - New Delhi
     Jeddah, SA       97.54 ms    0.0%    1790.34 Mbps   275.38 Mbps    Saudi Telecom Company
     Dubai, AE        194.32 ms   0.0%    1321.01 Mbps   309.34 Mbps    du - Dubai
     Hong Kong        159.04 ms   0.0%    917.13 Mbps    326.92 Mbps    Misaka Network, Inc. - Hong Kong
     Sydney           299.75 ms   0.0%    1772.00 Mbps   197.89 Mbps    Telstra - Sydney
     Perth            210.17 ms   0.0%    1133.06 Mbps   280.32 Mbps    Aussie Broadband - Perth
     Avg DL Speed       : 1369.21 Mbps
     Avg UL Speed       : 350.39 Mbps
     Geekbench 5 Benchmark Test:
     Single Core     | 482
     Multi Core      | 967
     Full Test       | https://browser.geekbench.com/v5/cpu/22810199
     Single Core     |  625
     Multi Core      | 1062
     Full Test       | https://browser.geekbench.com/v6/cpu/7495581
  • rootroot OG
    edited August 25
    I am curious if C1VHosting decides to cancel or discontinue some service, will they also send written requests to customers with ID validation and all that bureaucracy?
  • @c1vhosting said: Please open a ticket and send me ticket number.
    ticket #C1V_8811836_TCUSID
