@c1vhosting said:
Hi,
we are working on improving IO speeds on the HDD node.
Thanks for your patience.
but can we get boot/reinstall done before the IO improving?
We will need to manually reboot all VMs on POM2 to apply some disk IO adjustments. If your service is having an issue right now, please open a ticket and send me the ticket number.
@c1vhosting said:
Hi,
"#C1V_1094270_TCUSID"
After reinstall it just stuck in "The process of rebuilding a VM is in progress. Please wait." for two days
@c1vhosting said:
Hi,
Whenever in doubt, please refer to performance advisory
As mentioned in OP, this offer has struck has a balance between low cost and performance.
And do not forget the part -- where is this Data center housed?
@c1vhosting said:
Hi,
The number of VPS for each node should be controlled within 100
That's ridonkulous. Accordingly, here is only one piece of advice for you:
Quadruple your budget for your 'suggestions'.
If C1V really did as you suggested, the price of the VPS would be unacceptable.
I can't even find your similar products during Black Friday, nice wish though.
Your comparison is obviously inappropriate because of great difference in disk size: 20 GB vs 140 GB, not to mention your unknown traffic. I could do the same thing by referring to an OVH's offer of "1 core, 2 GB, 20 GB nvme, unlimited traffic @ 100 Mbps" for $0.97 monthly to claim your VPS is not good enough, but I won't do that, it's just inappropriate to compare.
My point here is I think C1V's offer is worth of the price, that's all. And I would advise everyone to pay with PayPal in case of early dead-pool which has happened many times to other providers here.
By the way, may I know the name of the provider of your YABS so that ...
Your comparison is obviously inappropriate because of great difference in disk size: 20 GB vs 140 GB, not to mention your unknown traffic. I could do the same thing by referring to an OVH's offer of "1 core, 2 GB, 20 GB nvme, unlimited traffic @ 100 Mbps" ….
I am yet to find any other vps that so consistent download rate of 1 gig … irrespective of location
and cpu vCore is Ryzen 7900
c1v vps has 2 gb memory, but one is expected to use only 50% of that. 140gb is only plus factor for c1v “on paper” as the vps is competing with 🐢 on speed.
other details you can find at looking at YABS I have posted.
If you think CPU performance is important, then choose what you like. I don't think C1V is stable enough to run important software, thus I only run some P2P, backup, private VPN on it, which consume less than 0.50 CPU all together (0.15 or less on other powerful VPS). A CPU of 200 GB5 points is enough.
@dev_vps said: Another example — cheaper than c1v
This one has 10gig data port too
Oh, that's very tempting. Can you kindly disclose the offer link so that I can buy it. Thank you.
If you think CPU performance is important, then choose what you like. I don't think C1V is stable enough to run important software, thus I only run some P2P, backup, private VPN on it, which consume less than 0.50 CPU all together. A CPU of 200 GB5 points is enough.
as you have mentioned… c1v has pretty limited use case. And I find other promo offers much better value
I use c1v for testing how database engine recovers from abrupt shutdown and no other provider is better than c1v vps.
I do not plan to renew c1v vps.
PS — there is a xyz days of notice required to cancel such high quality vps. Otherwise c1v rewards with renewal.
@dev_vps can you disclose the offer links of your performant YABS VPS which are very tempting.
@dev_vps said: PS — there is a xyz days of notice required to cancel such high quality vps. Otherwise c1v rewards with renewal.
I don't understand the above sentences. Isn't one simple click on 'Cancel when due' enough to cancel the service? Or just don't pay the invoice to cancel a service? Which provider are you referring to?
@foxone Thank you for the link. I think the cancellation procedure is very inconvenient. Customers should be careful about that.
Edit: After browsing the control panel of C1V, I found it has no differences between most providers in cancellation process: just click on the button of "Request Cancellation".
Speedtest.net
Location Latency Loss DL Speed UP Speed Server
Nearest 20.37 ms 0.0% 1211.29 Mbps 565.52 Mbps Uniconnect - Rome
Houston, TX 149.05 ms 0.0% 1088.12 Mbps 371.06 Mbps Ezee Fiber - Houston, TX
Chicago, IL 120.85 ms 0.0% 1368.67 Mbps 272.05 Mbps Enzu.com - Chicago, IL
Miami, US 139.18 ms N/A 1236.35 Mbps 313.16 Mbps Dish Wireless - Miami, FL
New York, NY 114.06 ms 0.0% 1259.03 Mbps 265.31 Mbps Surfshark Ltd - New York, NY
Miami, FL 129.51 ms 0.0% 1606.76 Mbps 304.89 Mbps ReliableSite Hosting - Miami, FL
Spokane, WA 169.34 ms 0.0% 902.60 Mbps 249.79 Mbps Crunchbits - Spokane, WA
Seattle, WA 177.93 ms 0.0% 1024.14 Mbps 302.30 Mbps Misaka Network, Inc. - Seattle, WA
San Jose, CA 167.67 ms 0.0% 912.56 Mbps 294.24 Mbps Misaka Network, Inc. - San Jose, CA
London, UK 34.76 ms 0.0% 1526.58 Mbps 541.56 Mbps VeloxServ Communications - London
Amsterdam, NL 38.08 ms 0.0% 1680.41 Mbps 430.51 Mbps 31173 Services AB - Amsterdam
Paris, FR 32.37 ms N/A 1394.39 Mbps 503.85 Mbps Axione - Paris
Frankfurt, DE 24.16 ms 0.0% 1513.99 Mbps 590.19 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 44.51 ms 0.0% 1724.87 Mbps 394.13 Mbps Play - Warszawa
Bucharest, RO 45.29 ms 0.0% 1238.89 Mbps 439.66 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Chennai, IN 166.94 ms N/A 1648.01 Mbps 295.31 Mbps Jio - Chennai
Mumbai, IN 131.45 ms 0.0% 1573.24 Mbps 293.54 Mbps i3D.net - Mumbai
Mumbai, MH 137.42 ms N/A 1683.78 Mbps 288.17 Mbps Jio - Mumbai
Delhi, IN 162.65 ms 0.0% 1333.86 Mbps 304.22 Mbps Tata Play Fiber - New Delhi
Jeddah, SA 97.54 ms 0.0% 1790.34 Mbps 275.38 Mbps Saudi Telecom Company
Dubai, AE 194.32 ms 0.0% 1321.01 Mbps 309.34 Mbps du - Dubai
Hong Kong 159.04 ms 0.0% 917.13 Mbps 326.92 Mbps Misaka Network, Inc. - Hong Kong
Sydney 299.75 ms 0.0% 1772.00 Mbps 197.89 Mbps Telstra - Sydney
Perth 210.17 ms 0.0% 1133.06 Mbps 280.32 Mbps Aussie Broadband - Perth
Avg DL Speed : 1369.21 Mbps
Avg UL Speed : 350.39 Mbps
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 482
Multi Core | 967
Full Test | https://browser.geekbench.com/v5/cpu/22810199
Test | Value
Single Core | 625
Multi Core | 1062
Full Test | https://browser.geekbench.com/v6/cpu/7495581
We got a mole in the hole! You gotta post those pictures somewhere sometime!
Forget about popcorns, this is a fireworks event!
I am curious if C1VHosting decides to cancel or discontinue some service, will they also send written requests to customers with ID validation and all that bureaucracy?
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
what data center?
HDD PLAN was sold out...
dont worry it will be back real soon
Just posted YABS for $12/year VPS (promo price got in May 2024)
https://lowendspirit.com/discussion/comment/184398/#Comment_184398
Strong enough to run even Windows Server 2022 OS.
Need more examples?
most likely new orders suspended until Disk IOPS is "tweaked".
@bliss
https://lowendspirit.com/discussion/comment/184231/#Comment_184231
Well, how much traffic is given monthly then? Most providers offer 1 or 2 TB then suspend VPS or reduce speed until next month.
5 TB per month … my usage is about half of that
Read c1v terms and conditions.
https://lowendspirit.com/discussion/6440/important-clarification-cancellation-process-at-c1v-hosting
@dev_vps can you disclose the offer links of your performant YABS VPS. It's boring to share a wonderful VPS without a purchase link.
another day .... another VM restart
c1v vps running Windows 11 Enterprise OS
what should I install next OS on c1v VPS?
.... let me try Oracle Linux OS ... see if it can be installed
Update
Oracle Linux 9.4 installed on VPS
my two(2) 400g storage node has been down since.....
Refer to Performance Advisory
Please open a ticket and send me ticket number.
@c1vhosting
ticket #C1V_8811836_TCUSID
