VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
16566687071104
  • @Wonder_Woman said:
    @nullnothere said:
    I just got here and there's a wonderful POST-BF Frenzy (that I clearly have no ability to comprehend).
    What just happened? I thought we had finished the hard part and had to go away to do some real work.
    There was more hard part, but more hard on the manual labor side of things
    WAS or IS ONGOING?
    Either way I'll let you get back to your code breaking and I'll wait for the tl;dr later.
    Intrigued.
    And feeling very bad about the whole timing of this thing - at the end of a long brain draining session, the horse power is just not there (clear proof on the wonders of sleep how it makes the brain mush without it).
    Sorry that I'm not able to pitch in (esp. in a timely way).
    On with your struggles...
  • KZQHGXBX not work
  • I assumed that meant
    Q####### -> Q#######
    After the conversion the Q kept it's position
    Thanked by (1)ariq01
    @Wonder_Woman said: it means you will exclude that letter from the decoding.
    Did I say anything else that contradicted this right here, and was the letter excluded from the decoding? I guess I should also ask, how do you guys determine the meaning of "excluded from decoding."
  • FAT32FAT32 OGSenpai
    I think the point is how can we confirm the letter is Q?
  • No winners with KZ[A-Z]HGXBX
    Because one way didn't work so we are trying the other way now haha
  • edited December 3
    Just this, I guess:
    therefore it remains as "A" after decoding
    I took that to literally mean A from one code should stay as A in the decoded form
  • And.... what really is the meaning of the word is? :p
  • edited December 3
    There are a couple other ways, and each leads to their own permutations and a completely different set of potential codes.
    @user123 said:
    It would also make a difference whether the Q was simply deleted or replaced with a placeholder letter/symbol before decoding.
    Edit: also whether or not we reinsert it as Q after decoding opens additional possible permutations. FML
    Yeah, excluding the Q from the Alphabet changes up the decoded result, but actually the Q is still in the same place, lol
    edited December 3
    @slownedstark said:
    you're able to remove it from the alphabet group during the decoding part, which resulted in the second set of codes we are currently working on. this was after decoding (without any removal in that alphabet group part of the decoding process) then swapping out the letter for [A-Z] did not work
    This is the closest response to what I'm requesting. So I just want to confirm:
    • You guys first did not remove it from the alphabet group, and those codes are what I initially asked a question about
    • In the frenzy of comments, you guys did a second set where it was removed
    If I ever mentioned that you guys should not remove it first (resulting in second set) please do quote it as that'd be foul on my part. Otherwise, it did have to be removed before the decoding (as in from the alphabet set.) So that's what we're looking for, whether or not I said anything at all that would make it sound like this was not an important/required step or if anyone interpreted it as such.
    Thanked by (3)ariq01 ZA_capetown FrankZ
    It's possible I'm thinking of a different cipher tried before, but deleting it vs replacing it with different letters changed other letters, too.
    So the second set was correct, but we still didn't find the right code...
    Thanked by (1)user123
    I am blind
    VPS Discounts and Reviews | Hosting Provider Directory & Check out the latest VPS offers and reviews to help you choose the best VPS service.
    edited December 3
    @Wonder_Woman said: So the second set was correct, but we still didn't find the right code...
    Can you provide the second set so I can compare it against mine? And when the second set was done, was it done including the ENTIRE code block, or only a snippet? As that would also affect the results (actually probably not.) I'm just trying to guess other reasons it'd be different.
  • With Q in the Alphabet:
    Without Q in the Alphabet:
    Thanked by (2)user123 ZA_capetown
    Oh my god, what?
    We were only converting the 4th portion, lmao
  • edited December 3
    @fyym said:
    @VirMach said:
    @fyym said: Below is my test result:
    Speedtest by Ookla
    Server: Axione - Paris (id: 28308)
    Result URL: https://www.speedtest.net/result/c/f4796ae4-8f8e-49e8-950b-21b73946df44
    It's most only 100Mbps.
    Try running the same test i you are trying to compare to others.
    wget -qO- bench.sh | bash
    The test results is as follows:
    -------------------- A Bench.sh Script By Teddysun -------------------
    Version : v2024-11-11
    Usage : wget -qO- bench.sh | bash
    CPU Model : AMD Ryzen 9 3950X 16-Core Processor
    CPU Cores : 2 @ 3500.000 MHz
    CPU Cache : 512 KB
    AES-NI : ✓ Enabled
    VM-x/AMD-V : ✓ Enabled
    Total Disk : 29.5 GB (1023.0 MB Used)
    Total Mem : 985.2 MB (72.1 MB Used)
    Total Swap : 512.0 MB (0 Used)
    System uptime : 0 days, 3 hour 31 min
    Load average : 0.00, 0.01, 0.00
    OS : Ubuntu 18.04 LTS
    Arch : x86_64 (64 Bit)
    Kernel : 4.15.0-20-generic
    TCP CC : bbr
    Virtualization : KVM
    IPv4/IPv6 : ✓ Online / ✗ Offline
    Organization : AS212477 RoyaleHosting BV
    Region : New York
    I/O Speed(1st run) : 282 MB/s
    I/O Speed(2nd run) : 1.0 GB/s
    I/O Speed(3rd run) : 1.3 GB/s
    I/O Speed(average) : 879.1 MB/s
    Node Name Upload Speed Download Speed Latency
    Speedtest.net 78.72 Mbps 92.77 Mbps 76.46 ms
    Los Angeles, US 77.70 Mbps 87.78 Mbps 78.80 ms
    Dallas, US 84.70 Mbps 85.69 Mbps 47.98 ms
    Montreal, CA 86.14 Mbps 84.54 Mbps 20.23 ms
    Paris, FR 80.40 Mbps 93.44 Mbps 90.75 ms
    Amsterdam, NL 82.66 Mbps 81.86 Mbps 72.66 ms
    Beijing, CN 79.71 Mbps 85.27 Mbps 262.80 ms
    Hong Kong, CN 5.78 Mbps 1.17 Mbps 224.60 ms
    Singapore, SG 74.50 Mbps 90.35 Mbps 261.80 ms
    Tokyo, JP 84.11 Mbps 92.63 Mbps 176.03 ms
    Finished in : 4 min 52 sec
    Timestamp : 2024-12-01 14:11:45 GMT
    Okay, maybe something's wrong. Create a ticket and provide access.
    Hello, @VirMach Ticket #232897 has been created.
  • Decryption by chunks and the whole makes different results
  • QJFYSUFSPIAQUGYTNCJQLPUGHSNYPWYQSFAVOYQQKQHVJTOBQBMNYXHSQTRPAVLSZLQYGJSNMQFYTOVJHYMZQOKPVXQOTNSMDYBQFLVKOZYMQLXPTBSQFVRYRQHVTBMLQPOXNFZKUVKTBSHQQLPVBYMXTXQVBRLSYQZPNLMSNSLQKTVXQVKRLPSBLJQTFSYMHVQRLPYTBMVYNFQJQTLRPVSMQLKPTXVYZJQYPFVBPQXLNYSMRQSFLVPTKXQOYJTBJQTLSFYBOMXYPVQJQKTVYZLMQPLNSBYXZBYQJLSTFLKQMSXPOYQKTRBJVNQTLPYKTJBMNQZYLYQVTFSBQRSPLFVBPQXMZLYKKMSYQLOJLJNVQXTZNSPQFJYKTQLSPYOMMXYBZQJK
    So it should have been these
    HVQRLPYT
    BMVYNFQJ
    QTLRPVSM
    QLKPTXVY
    ZJQYPFVB
    PQXLNYSM
    RQSFLVPT
    KXQOYJTB
    Thanked by (2)ariq01 localhost
    Oh my god, what?
    All I'm seeing is that I saw two different blocks than my results, and I was able to replicate my results. I'm trying to figure out how to get it to display like yours.
    HVQRLPYT
    BMVYNFQJ
    QTLRPVSM
    QLKPTXVY
    ZJQYPFVB
    PQXLNYSM
    RQSFLVPT
    KXQOYJTB
    Okay yes, it should have been those. Sorry I was just trying to be careful with my words, I'm a little confused as well switching between tabs and trying to get it to match your results staring at a bunch of jumbled letters. From my understanding it would make a difference whether or not it'd be the whole block but I'm only 90% sure so I added that little disclaimer in my edit.
    Thanked by (1)localhost
  • This might be the least enthusiastic I've been to anticipate (page) 69. :'(
    Thanked by (2)Wonder_Woman ariq01
    Sorry :(
    Thanked by (2)user123 vyas
  • edited December 3
    Nooooo! 50% off would have been nice :'(
    99.99
    PER YEAR
    VIRT
    KVM
    RYZEN SKU# V03-XD
    RAM
    16384MB
    DDR4 RAM
    CPU
    6 Core
    CPU vCORE
    HDD
    1200GB
    SSD (NVMe)
    <span>BANDWIDTH</span>
    20480GB
    BANDWIDTH
    IPs
    1 IPv4
    DEDICATED IPv4
    0h 11m 36s
    Edit: 90% off would have been even nicer lol
    Thanked by (1)Wonder_Woman
  • edited December 3
    @Wonder_Woman said:
    Sorry :(
    Don't apologize. You led us farther than we would have got ourselves :P.
  • wa o
    Offer #1018
    SKU: RYZEN SKU# V03-XD
    6 cores
    16384MB RAM
    1200GB NVMe Storage
    1 IPv4
    20480GB Bandwidth
    CHICAGO, IL
    $99.99 per YEAR
    edited December 3
    @Wonder_Woman said:
    Sorry :(
    Okay in this case, there will be a consolation prize. I shouldn't have added confusion by trying to get you guys to save time on checking a specific chunk and should have mentioned to still decode the entire block.
    I think what would be a fair consolation prize in this case is that we divide the 49 codes into 1/6th block for 1/6th of the work that was done to get to the finish line. I'm going to start generating eight codes and messaging them to the people that made the most to least comments or appear to have been most to least pivotal in doing the final work. It might have been more than 8 people that did that, so it's just going to be the top 8 from my memory and checking the thread. It'll be private messaged as I don't want anyone else doing none of the work/contribution and just using the codes.
  • edited December 3
    HVQRLPYT
    BMVYNFQJ
    QTLRPVSM
    QLKPTXVY
    ZJQYPFVB
    PQXLNYSM
    RQSFLVPT
    KXQOYJTB
    Doesn't work... when I try
