1326327329331332406
  • edited December 2024
    My NYC server down for a second time this week... It's never @Virmach 's fault ofc, first time was I/O abuse from users, now it's bec of: a missing tech/bad switch/holiday season timing, etc... Did I mention no apology given?.. No time for that, too busy coding candles..
    🤡 "We can confirm that this is not an issue with any servers, network, or power equipment on our end." 🤡 "We have temporarily paused controls for this service as we are performing maintenance on the server." 🤡 "The servers are working, they are just not connected to the internet!" 🤡
  • @VirMach said: I really liked that block too. I kept it longer than I should, it was technically one of our more expensive ones.
    Something wrong with you guys.
    I once gave an extremely important presentation to IBM's top 100 companies and called my self a Nechi Terd ever since then, I have dropped that expression and loving 'funny' things.....
    Thanked by (1)cybertech
  • N.Y node is offline.
    @tenpera said: N.Y node is offline.
    Node is the wrong word: there is more than one node!
    [Edit]Needed caffeine
  • NYCB040 is back for me.
  • @yoursunny said:
    New York City is sinking into the ocean?
    Host node: NYCB031
    We cannot load the controls for your service at this time.
    Chicken came back after 7 hours 48 minutes.
    @VirMach said:
    We also ordered in two new switches from our provider who was going to preconfigure them (it's a different brand, I already barely know how to work the ones we have and defer networking usually, but this one I definitely know nothing on.)
    You should stick with switches that support the same operating system, and develop your automation to configure every switch through its API rather than command line or configuration files.
    We have success with SONiC switch operating system.
    My collaborators were seen using RESTCONF protocol to configure their switches.
    Thanked by (2)adly mandala
  • My first VirMach downtime - I’ll have to have a cold one to celebrate. B)
    Out of interest, what are the brands being used here?
    Thanked by (1)mandala
    @adly said: Out of interest, what are the brands being used here?
    Let me make an @Virmach - alike answer here for ya:
    I am such a specialist of brands & switches, I could write a book about them! The fact is: I picked an old brand because it was a lot cheaper and better, I know I have to code a custom switch myself, it is on the to-do list. In reality: all of this is due to the wear & tear of the users: those idiots keep sending & receiving packets every nanoseconds, which creates a heat up of the IC, which then fails even before reaching its MTBF... All this to say: I don't care if you were offline, I won't spend what is required for a good switch, and now I will go code my next script: Fireworks Deals 2025~. And good luck trying to find the Debian 12 OS template from our control panel: there is none & I don't care!
    Thanked by (1)remy
    Can I say, told you...
  • My NY VPS was down for about 7Hrz maybe. Can we get a 70% discount on our next purchase? =)
  • VVVVVVIIIIIIIIIIIIIIIIIIIIIIIIIRRRRRMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH
    Thanked by (2)admax cybertech
    @jcn50 said: My NYC server down for a second time this week... It's never @Virmach 's fault ofc, first time was I/O abuse from users, now it's bec of: a missing tech/bad switch/holiday season timing, etc... Did I mention no apology given?.. No time for that, too busy coding candles..
    If you don't want anything to be explained and it bothers you, just pretend I said "sorry, sorry, sorry, sorry, completely my fault, sorry, I broke it, sorry. I was too busy getting distracted setting up a sale, if I had been there it wouldn't have happened, sorry, nothing occurred other than it being my fault, sorry."
    We use Juniper. The reasoning being they were the most affordable at the time & we were somewhat familiar with Juneos. The provider we use wants to use Arista as they're more familiar and confident with them.
  • With IPv9 this would have never happened as it does automatic switch bypass if it detects them being faulty.
    Thanked by (3)admax yoursunny Blembim
  • @VirMach did the more knowledgeable tech go in this morning and fix it? is the new arista stuff in place?
  • Greetings
    Debian 12 has been released for over a year but it is not listed as a VPS reinstall template. Is there a good reason it is missing?
    Thanks.
    Thanked by (1)jcn50
    world's most stable Juniper deployment
  • Good call on Juniper or Arista.
    Could've been Brocade. I've nearly seen a network engineer nope out of a career over a Brocade edge router and weeks of hell.
    Thanked by (1)admax
    @Newyawker said:
    Greetings
    Thanks.
    SolusVM doesn't work well with it. They've tried and failed to create a fully functional template for it, and we're also running into problems. They've said it's a confirmed issue with templating on the operating system our host nodes run on (standard.) I've probably created several dozen templates that all end up having some strange issue.
    What I'm going to try to do next is take their template and then fix it but I'd prefer not to do that since I don't know what other problems it may have...
    Has anyone installed Debian 12 when we had it from SolusVM and worked out all the problems? Is it working for you to this day?
    Thanked by (2)Newyawker admax
    Not that I know of, it seems like the most likely outcome is all my fiddling did something but only after I was frustrated and went to sleep. Then it magically decided to fix itself. Well, not that magical, what I was doing was supposed to have a positive effect so I guess it did but I don't really want to take the credit because I still don't really understand it much. Just very light educated guesses that wouldn't make it worse trying to get the communication between the switches to re-attempt and stick. I still take zero credit for anything that happened.
    I haven't got a solid confirmation on whether or not anything was done on their end but it doesn't seem like it. That's why I'm looking into it further now and why the storage server is still offline (on purpose, it's what may have set everything off.)
    Arista is not in place and no update on that. We just ordered it through our provider and there were delays. No ETA. I actually asked for another update because unless it's getting there in a week or two, I need to order in a third or fourth EX4300, but I'm personally leaning toward it not necessarily being hardware this time around (which is actually somewhat worse in my opinion, it means there's some weird configuration issue and I'm not the one who set it up.)
    Edit - Confirmed, they didn't do anything on their end so the most likely things that happened (1) it decided to randomly break itself and fix itself, (2) my button mashing did something positive. Still investigating while we wait on their knowledgeable tech's availability to be provided.
    Thanked by (2)FrankZ admax
    @VirMach said:
    @Newyawker said:
    Greetings
    Thanks.
    Virtfuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuusion
    Thanked by (2)admax burntascii
    @cybertech said:
    @VirMach said:
    @Newyawker said:
    Greetings
    Thanks.
    Just talking out of turn here...
    One of the reasons I expect hosts hold back from converting to Virtfusion is that VMs don't appear to migrate easily from SolusVM. Other providers that have made this migration have recreated my VMs, not migrated. I expect that, basically needing two separate billing panels while converting, and rewriting all the in-house code, would be a big ask of VirMach.
    Maybe a separate brand would work. Virt-Mach, oh wait.
    Thanked by (1)sh97
    @cybertech said:
    @VirMach said:
    @Newyawker said:
    Greetings
    Thanks.
    if the nodes that went down which were eventually migrated/consolidated etc were shifted to VF....half of them would be on VF by now maybe?
    Thanked by (1)admax
  • @FrankZ said:
    @cybertech said:
    @VirMach said:
    @Newyawker said:
    Greetings
    Thanks.
    It's not that hard to convert, I think most LE* providers are just too lazy/incompetent to put the effort in. I'd like to eventually see Virmach make the switch but I'm also not that offended by Solus anymore. It works for the most part and I don't hang out in the VPS management screen all day.
    @VirMach said:
    @Newyawker said:
    Greetings
    Thanks.
    Not trying to do comparison, but H0stSail*r provides a working Debian 12 Template under their SolusVM.
    My VPS from ----Nerd is running smoothly on a Debian 12 template.
    Okay I've spent most of today really looking into our switches and making some improvements. I broke it for a couple minutes, I'm glad no one noticed. Our monitoring system didn't catch it either.
    It's still possible I did something weird I shouldn't have but I still haven't heard back from the provider so I'm doing what I can to prevent another long outage and so we can move forward with bringing the storage connectivity back online. Anyway, I'm happy with what I discovered and changed. I hope. We had another network engineer do most of this previously and I don't like how they did it, I think the configuration is what could have caused some of these problems. I might be wrong, I don't know. When I say I don't like how they did it, I literally mean I, as in me, didn't like what I saw.
    My changes might not necessarily fix the big issue but it should at the very least have improved some things in a measurable way to where it could have some positive impact until we switch over to the Aristas.
    @Fritz said:
    @VirMach said:
    @Newyawker said:
    Greetings
    Thanks.
    On a Ryzen node set up in 2022 or later? Because we could have also had it working on E5's set up before 2022. This is specifically a problem on newer installations on Almalinux after the whole CentOS thing happened.
    There also is a workaround for it where you can check off a lazy option for corrupted templates, but I don't want to do that because it would impact some other things negatively. Of course I'm also not saying another host couldn't have figured it out, but SolusVM hasn't figured it out. I guess that's not saying much.
    @Fritz said:
    @VirMach said:
    @Newyawker said:
    Greetings
    Thanks.
    Yes, can confirm. Debian 12 Works with 7950X fine with Greencloud and Nerd.
    @sh97 said: Yes, can confirm. Debian 12 Works with 7950X fine with Greencloud and Nerd.
    Okay, I'm going to try something then. That's newer so that's a good clue. Thanks.
    Thanked by (1)sh97
    Love the spirit!!
