@dev said:
Wow, nanokvm and now this! Any plan to add more slot for test in Tokyo soon? I do not qualify with my les account but do with my baller account.
Your request got stuck while in deployment, I did a reset.
Please apply again.
The location you want to deploy was under heavy packetloss at this time, which caused issues.
Yet, the system does a rollback but does not cancel the pending request.
I see no error or anything stuck.
You have to complete the request within 30 minutes or it gets deleted.
I mean you posted a token right, so then you should enter a password for your account and if you do not do that within 30 minutes, the request gets cleaned up.
It got stuck on "deploying" and never told me anything
Yea the first time, you deployed in Swiss, due to heavy packetloss the system failed to deploy.
If your request is in deploy status, it won't get deleted, so if it would get stuck at some point, I can investigate it.
But if your request, is still in verification or account setup, it will get deleted after 30 minutes, of inactivity.
And since there is nothing stuck or a pending request in the database, your second request never reached deploy.
The system scanned your post, I found the entry in the database, so you should be on the account setup.
Request rejected
Your request can get rejected for the following reasons:
You provided an invalid account
You do not meet the requirements
Using a VPN or Proxy
If you think there is an technical error,
please let us know.
Request rejected
please let us know.
You select Hostballs and the Account there does not exist, so the system rejected it.
I changed the forum select, so there is not longer a default forum selected.
Also, there is now a notification, about that the request will expire in 30 minutes.
MS said:
I entered correct LET username but the message says 'Invalid username.'.
I updated the regex, so It will accept your username now.
Besides, as I said before, as long the LET thread is not posted, it wont work if you go on the website and select Lowendtalk.
@Neoon said: Since you cannot post the token on LET.
Oh, I was gonna ask if the token could be posted here. I guess not, so I will wait for the post there.
The Request is bound to the forum, you requested it from.
Otherwise, it would be exploitable aka someone could pick your username on LET and get a new account here to validate it.
@Neoon said: The Request is bound to the forum, you requested it from.
Although my username is taken here and there, I agree, that could work for other usernames of long standing users that are not yet registered here. I didn't thank of that. Thank you.
Yep, Use full for what I'm trying to do with NAT VM's in general running a one file status page which checks all the servers and services I need to monitor and displays in a page.
Also for some reason the my LXC JP is faster than my VM on Vultrs network so looking forward to it.
StarryDNS has a decent network in jP; that could explain it.
At some point, yes, but no ETA.
Please apply again.
ITS WEDNESDAY MY DUDES
Kudos @Neoon looks like another great project. Keep up the good work
26d7-d40a-f519-5e27 trying again
Thanks to @FAT32 for the acceleration.
But the Thread does not exist yet, but will soonTM.
My vps still got stuck btw![:( :(](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/frown.png)
Request rejected
please let us know.
b81d-82d9-c497-224f
let's try
Is this IPv6 only or will there be an NAT IPv4 in the future?
It's IPv6 + NAT IPv4.
Awesome! I'll have to wait until the LET thread to apply then, my LES account doesn't qualify but I believe the LET account should.
OK, that's right.
AU and JP are OOS![:( :(](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/frown.png)
@Neoon let me know if you want the specs for the AU PoP increased/another VM deployed.
Yes, I take the entire node, thx bay.
Yes and there will be no restock until posted on LET.
CH, AU restocked.
NO added, with a special package.
Please only pick that package if you really have a use for it.
Anyone interested in HAProxy support?
Not in 128MB instance..
That would be nice.
Well, enough for a php script or html.
No one said you need to run MariaDB.
