microLXC Public Test
1246722
    @Neoon said:
    Melbourne is back Online, since it suffered a total data loss on Saturday.
    It took a bit longer as expected due to network issues, which now have been solved.
    Anyone who has been affected has been notified.
    Happy deploying.
    Thanks for the work! :)
  • 54fb-39f1-f65f-a0e7
    edited August 2020
    @terrorgen said:
    54fb-39f1-f65f-a0e7
    Well the deployment did not went well.
    Currently images are not preloaded, means they get fetched from the LXD image server.
    Due to APAC and shitty mirrors, it can happen, that its not done in time and the deployment process is considered as failure.
    I need to preload all images to fix that issue, which I will do hopefully this week also.
    I removed the request, so you can if you want... deploy it again immediately, the image should be now preloaded.
    Sorry for the issue.
    edit: Looks like SG is facing network issues currently https://stats.uptimerobot.com/J6jQDu8Kry
    Singapore IPv6 has been fixed, enjoy.
  • 0009-7cf5-d7c0-b464
    In about 2 weeks, the system will check for certain activity on the containers.
    Means for you, you should have logged into the panel or container before this update is released.
    After this update, you have to login every 60 days, either ssh into the container or login into the panel.
    If you fail to meet these requirements, your container goes into a 7 day grace period, afterwards it will be stopped, 7 more days and your container will be deleted.
    The reason why I did choose a login based activity is, depending on your use case you may have low traffic,memory or cpu needs, so we cannot really pin it down by that.
    We will see how this works and it might be changed later but for now it should be fine.
    Thanked by (3)bdl Ganonk ferri
  • Token: a1ce-2b30-c6a7-6254
  • ouch, does not meet any of those requirements :p
    NL has been rebooted for a network maintenance, SR-IOV has been enabled for better network performance.
    Thanked by (1)Ganonk
    edited November 2020
    NO will be down for a short period on Monday morning (around 8:00 GMT+1), due to a memory upgrade + microcode update.
    So we can add a few more slots.
    Today, I also dropped a few updates:
    • a few design changes, for example the new new account page:
    • Existing accounts are now considered as verified, means you can delete & deploy without verification
    • Statuspage is now linked in navbar https://status.microlxc.net/
    However, the notifications are not fully in production yet, you can already add your email + confirm it but you wont get any emails yet. We likely will handle this by hand for now until we enable automatic suspension.
    Thanked by (2)bdl Ganonk
    edited December 2020
    Regarding the ongoing issue with failed deployments.
    I did manage to narrow it down, sadly it seems like LXD is at fault here.
    If you send LXD a container creation request, it simply does not reply always.
    But creates the container in the background, which is kinda bad, because it would also mean it can affect reinstalls.
    However, you can start another reinstall if the first one fails, since it seems to work on the second try for some reason.
    It does not look like a timeout problem or such, as it does not matter if you set the timeout to 60s, LXD just wont answer.
    There is a theoretically fix for that, that would kinda duct tape it but I would rather fix it at the core.
    I will post again once I fixed it, since is is kinda essential, I have put everything on HOLD for this project.
    Thanked by (2)Ganonk ferri
    Maintenance announcement:
    • SG will be rebooted tomorrow night, to help troubleshoot the ongoing deployment issues.
      All Containers will be automatically started after the reboot, it should not take longer than 5 minutes.
    • NL will be physically moved to another data room next week, more information will follow
    Thanked by (3)bdl ferri Ganonk
    edited January 2021
    Another Maintenance announcement:
    • NL will be moved into another rack on Tuesday, it will be de racked and racked up again so should not take long, no exact time window on that.
    • LA, SG and NO have currently issues with the LVM backend, which results in poor I/O performance or failed deployments in SG.
      The Plan would be for these locations, to migrate existing containers to a new LVM pool, which should solve these issues.
      However, the operation could lead to data loss so I advise anyone if you have a container in one of these locations, take a backup before they will be migrated.
    This will take place at the following days:
    LA Friday, 16:00 GMT, approximately 1 hour
    SG Friday 19:00 GMT, approximately 1 hour
    NO Sunday, 19:00 GMT, approximately 2 hours
    The Downtime will likely to be shorter for each container, as long nothing comes in-between.
    During the maintenance, you won't be able to control the container via microlxc.net.
    After the maintenance stock will be available again on these locations, including NO.
    Tokyo is not affected by this, however if we upgrade NL and AU, we likely will performance this maintenance additional or if it becomes necessary.
    CH will be not moved to another LVM Backend, since I plan to discontinue it, due to the network related issues.
    However don't plan to discontinue CH until we have a replacement, currently I am still looking for one.
    I keep you updated on this.
    Thanked by (5)ferri bdl Ganonk Asim atomi
  • thanks for your updating announcements
    "Thursday" not Tuesday, I am sorry for that mistake.
    Thanked by (2)Ganonk bdl
    NL maintenance starting in the next hours, new deployments have been suspended.
    LA maintenance is done, total downtime was 3 minutes + about 1 minute for each container.
    Sadly IPv6 died again, we are working on it, so the downtime was a bit higher + a few reboots.
    I/O feels a lot faster now, looks good.
  • Is MicroLXC same as LXC in LDX or mini version? Or you brand it?
    Is there GUI tool available over LXC [other than LXDUI] for complete cluster management for newbies [free/paid]?
    SG Maintenance is done, LA v6 works again, thanks Virtualizor and thanks @seriesn
    @gks No and No.
    No idea, I mean LXD has a Rest API, what I do use, and if you use that, you have nearly endless possibilities.
    Thanked by (2)gks seriesn
  • vyasvyas OGSenpai
    Thanks for the awesome work. I had written a short review of MicroLXC on my blog a few days ago. Added this discussion to keep track of updates.
    Please tell me what is the Control Panel being used in this project, which is pictured on @vyas' blog page. Thanks!
    It's a custom built one.
    Is it open source? If yes, where are the sources? Thanks!
  • vyasvyas OGSenpai
    May the Source Be With You. By A Vyas
    Thanked by (2)yoursunny Not_Oles
  • AsimAsim OGServices Provider
    @Neoon said: SG Maintenance is done
    the issue I face "Configure instance: Failed to mount LVM logical volume: Failed to mount '/dev/secondary/containers_lxccef844a4' on '/var/snap/lxd/common/lxd/storage-pools/secondary/containers/lxccef844a4': no such device or address"
    may be it needs some manual review
    Cannot deploy first container, I get "You recently deployed a container, please wait."
    Every time I stop visiting your website, all of a sudden there’s a content tsunami. When I do visit regularly, it feels like my fridge. Mostly empty.
    Y U do dis
  • vyasvyas OGSenpai
    Y U do dis
    Just for you my friend, just for you. I publish multiple times to irritate you
    Now the RSS feed is working again.
    Aiming for one new post everyday for the first month. As a moving target, might keep extending it.
    I disabled lvm tools host again, seems to be causing these issues.
    When I was working on the lvm volumes it was suggested to enable the lvm host tools to prevent issues but instead it was causing these.
    Please try again, I did try 4 deploys on SG in a row, seems to work fine now.
    Additional, I switched the image source to local, should be faster and more reliable on deployments.
    The Image server dislikes APAC.
    Sadly its not.
