Post some YABS bench here
12425272930145
    Tuned a little bit 4k test :)
    Wed 21 Jul 2021 02:21:47 PM CEST
    Processor  : AMD Ryzen 5 3600 6-Core Processor
    CPU cores  : 12 @ 3600.000 MHz
    RAM        : 62.7 GiB
    Swap       : 0.0 KiB
    Disk       : 1.8 TiB
    Read       | 967.83 MB/s (241.9k) | 5.51 GB/s    (86.2k)
    Write      | 970.38 MB/s (242.5k) | 5.54 GB/s    (86.6k)
    Total      | 1.93 GB/s   (484.5k) | 11.06 GB/s  (172.9k)
    Read       | 7.45 GB/s    (14.5k) | 7.71 GB/s     (7.5k)
    Write      | 7.85 GB/s    (15.3k) | 8.23 GB/s     (8.0k)
    Total      | 15.30 GB/s   (29.8k) | 15.94 GB/s   (15.5k)
    Clouvider       | London, UK (10G)          | 3.43 Gbits/sec  | 4.27 Gbits/sec
    Online.net      | Paris, FR (10G)           | 6.52 Gbits/sec  | 6.94 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 949 Mbits/sec   | 1.25 Gbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 6074
    Multi Core      | 32240
    Full Test       | https://browser.geekbench.com/v4/cpu/16272144
    Geekbench 5 Benchmark Test:
    Single Core     | 1346
    Multi Core      | 7801
    Full Test       | https://browser.geekbench.com/v5/cpu/8918377
    Thanked by (1)cybertech
    edited July 2021
    10/2 Gbit/s uplink. Network is awesome all around the world.
    Processor  : Intel(R) Xeon(R) E-2274G CPU @ 4.00GHz
    CPU cores  : 8 @ 4399.999 MHz
    RAM        : 62.5 GiB
    Swap       : 0.0 KiB
    Disk       : 1.7 TiB
    Read       | 958.09 MB/s (239.5k) | 1.36 GB/s    (21.3k)
    Write      | 960.62 MB/s (240.1k) | 1.37 GB/s    (21.4k)
    Total      | 1.91 GB/s   (479.6k) | 2.73 GB/s    (42.7k)
    Read       | 1.57 GB/s     (3.0k) | 1.69 GB/s     (1.6k)
    Write      | 1.65 GB/s     (3.2k) | 1.80 GB/s     (1.7k)
    Total      | 3.22 GB/s     (6.2k) | 3.50 GB/s     (3.4k)
    Clouvider       | London, UK (10G)          | 1.96 Gbits/sec  | 8.26 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.96 Gbits/sec  | 8.90 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.84 Gbits/sec  | 2.33 Gbits/sec
    Single Core     | 6249
    Multi Core      | 20323
    Full Test       | https://browser.geekbench.com/v4/cpu/16272143
    Single Core     | 1325
    Multi Core      | 4853
    Full Test       | https://browser.geekbench.com/v5/cpu/8918372
    RAM        : 62.5 GiB
    Swap       : 0.0 KiB
    Disk       : 1.7 TiB
    Single Core     | 6249
    Multi Core      | 20323
    Single Core     | 1325
    Multi Core      | 4853
    wow which provider?!
    @cybertech OVH.
  • DO droplet, got it free a little while ago from this thread
    #                     v2021-06-05                    #
    Thu Jul 22 00:57:05 UTC 2021
    Processor  : DO-Regular
    CPU cores  : 1 @ 2294.608 MHz
    RAM        : 991.0 MiB
    Swap       : 0.0 KiB
    Disk       : 25.0 GiB
    Read       | 124.18 MB/s  (31.0k) | 317.49 MB/s   (4.9k)
    Write      | 124.51 MB/s  (31.1k) | 319.16 MB/s   (4.9k)
    Total      | 248.69 MB/s  (62.1k) | 636.65 MB/s   (9.9k)
    Read       | 330.83 MB/s    (646) | 333.09 MB/s    (325)
    Write      | 348.40 MB/s    (680) | 355.28 MB/s    (346)
    Total      | 679.23 MB/s   (1.3k) | 688.38 MB/s    (671)
    Clouvider       | London, UK (10G)          | 1.70 Gbits/sec  | 2.37 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.87 Gbits/sec  | 2.26 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 1.82 Gbits/sec  | 2.48 Gbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 510 Mbits/sec   | 35.8 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.74 Gbits/sec  | 6.89 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 1.93 Gbits/sec  | 3.72 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | busy            | 3.01 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 75.2 Mbits/sec  | 1.59 Gbits/sec
    Clouvider       | London, UK (10G)          | 1.67 Gbits/sec  | 2.37 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.86 Gbits/sec  | 2.22 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 1.87 Gbits/sec  | 2.47 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.98 Gbits/sec  | 7.36 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.88 Gbits/sec  | 2.96 Gbits/sec
    Single Core     | 703
    Multi Core      | 706
    Full Test       | https://browser.geekbench.com/v5/cpu/8928411
    juicy network
  • YABS doesn't run on a Cobalt RaQ4r
    root ~ > bash yabs.sh
    #                     v2021-06-05                    #
    Sat Jul 24 22:05:16 BST 2021
    yabs.sh: [[: command not found
    yabs.sh: i586: command not found
    Architecture not supported by YABS.
  • I tried using bash2 and got a bit further. Commented out a section in yabs and got:
    #                     v2021-06-05                    #
    Sat Jul 24 22:41:00 BST 2021
    Processor  : AMD-K6(tm)-III Processor
    CPU cores  : 1 @ 448.210 MHz
    AES-NI     : ❌ Disabled
    VM-x/AMD-V : ❌ Disabled
    RAM        : 505.0 MiB
    Swap       : 128.4 MiB
    yabs.sh: [: : integer expression expected
    Disk       : 0.0 KiB
    Preparing system for disk tests...curl: option --retry is unknown
    curl: try 'curl --help' for more information
    Fio binary download failed. Running dd test as fallback....
    yabs.sh: command substitution: line 1: syntax error near unexpected token `&'
    yabs.sh: command substitution: line 1: `dd if=/dev/zero of=$DISK_PATH/$DATE.test bs=64k count=16k oflag=direct |& grep copied | awk '{ print $(NF-1) " " $(NF)}''
    yabs.sh: DISK_WRITE_TEST_RES+=(  ): command not found
    yabs.sh: command substitution: line 1: `dd if=$DISK_PATH/$DATE.test of=/dev/null bs=8k |& grep copied | awk '{ print $(NF-1) " " $(NF)}''
    yabs.sh: DISK_READ_TEST_RES+=(  ): command not found
    dd Sequential Disk Speed Tests:
           | Test 1      | Test 2      | Test 3      | Avg
    Write  |             |             |             | 0.00   MB/s
    Read   |             |             |             | 0.00   MB/s
    yabs.sh: line 602: syntax error near unexpected token `(('
    yabs.sh: line 602: `    for (( i = 0; i < IPERF_LOCS_NUM; i++ )); do'
    I think basically it's all just too old lol.
    Thanked by (1)_MS_
  • vyasvyas OGSenpai
    edited July 2021
    Ran Yabs on my late 2012 Macbook Pro -
    Clean install of Manjaro on OEM 128 GB disk. While I wait for the adapter to arrive that will help me upgrade to a 512 GB SSD.
    Question: Why the Zeros for disk speed?
    I used the command
     curl -sL yabs.sh | bash -s -- -r9
    bench.monster gave the following:
    Disk Speed:
    1st run : 2.9 GB/s
    2nd run : 2.7 GB/s
    3rd run : 2.9 GB/s
    Average : 2901.3 MB/s
    Thu Jul 29 17:08:32 IST 2021
    Processor  : Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
    CPU cores  : 4 @ 1759.019 MHz
    RAM        : 7.7 GiB
    Swap       : 8.8 GiB
    Disk       : 101.8 GiB
    Read       | 0.00 KB/s        (0) | 0.00 KB/s        (0)
    Write      | 0.00 KB/s        (0) | 0.00 KB/s        (0)
    Total      | 0.00 KB/s        (0) | 0.00 KB/s        (0)
    Clouvider       | London, UK (10G)          | 7.96 Mbits/sec  | 9.81 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 8.53 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 7.25 Mbits/sec  | 5.83 Mbits/sec
    Single Core     | 3359
    Multi Core      | 6253
    Full Test       | https://browser.geekbench.com/v4/cpu/16283053
    Single Core     | 646
    Multi Core      | 1201
    Full Test       | https://browser.geekbench.com/v5/cpu/9060975
    Output from the 'h' flag below
    Thu Jul 29 17:26:55 IST 2021
    Usage: ./yabs.sh [-fdighr49]
           curl -sL yabs.sh | bash -s -- -{fdighr49}
    Flags:
           -f/d : skips the fio disk benchmark test
           -i : skips the iperf network test
           -g : skips the geekbench performance test
           -h : prints this lovely message, shows any flags you passed,
                shows if fio/iperf3 local packages have been detected,
                then exits
           -r : reduce number of iperf3 network locations (to only three)
                to lessen bandwidth usage
           -4 : use geekbench 4 instead of geekbench 5
           -9 : use both geekbench 4 AND geekbench 5
    Detected Arch: x64
    Detected Flags:
           -i, skipping iperf network test
           -g, skipping geekbench test
           running geekbench 5
    Local Binary Check:
           fio not detected, will download precompiled binary
           iperf3 not detected, will download precompiled binary
    Detected Connectivity:
           IPv4 connected
           IPv6 not connected
    Exiting...
    Also,
    curl -sL yabs.sh | bash -s -- -ig
    gave
    @vyas Install fio manually via brew.
  • vyasvyas OGSenpai
    edited July 2021
    Thanks- forgot to mention I run Manjaro Linux. YABS was on Manjaro
    Then it should work, at least as i know Manjaro is based on Arch. Maybe there is some misconfiguration for Arch(Manjaro) tho?
  • MasonMason AdministratorOG
    edited July 2021
    Yikes... yeah don't think it's gonna fare well on something that old. Lots of bash-related syntax errors there. Maybe I could enforce some sort of minimum bash version or something rather than spewing out junk output.
    @vyas not too sure about that one. I'd do what @LetMeBeSad suggested and install fio natively to see if it runs that way (the script will detect the locally installed version and use that instead). If that fails too, then I'd know it's not an issue with the binary that I compiled
    Thanked by (2)vyas Not_Oles
  • vyasvyas OGSenpai
    edited July 2021
    Thanks @LetMeBeSad and @Mason
    installing fio worked.
    Not bad for a 10 year old OEM disk. (Samsung SSD for MBP12)*
    Read       | 62.51 MB/s   (15.6k) | 64.78 MB/s    (1.0k)
    Write      | 62.62 MB/s   (15.6k) | 65.18 MB/s    (1.0k)
    Total      | 125.13 MB/s  (31.2k) | 129.96 MB/s   (2.0k)
    Read       | 108.74 MB/s    (212) | 116.51 MB/s    (113)
    Write      | 114.52 MB/s    (223) | 124.27 MB/s    (121)
    Total      | 223.26 MB/s    (435) | 240.78 MB/s    (234)
    *But allows me to build a case to upgrade the drive. Not just for storage but also speed.
    @vyas said: installing fio worked.
    Interesting. So my prebuilt fio has some issues with Manjaro (and possibly Arch?) that I'll have to investigate in the future.
    Glad the fio install worked :)
  • HostHatch 250GB big plate chicken in Chicago
    root@vps0:~# curl -sL yabs.sh | bash
    #                     v2021-06-05                    #
    Fri 30 Jul 2021 08:36:28 PM EDT
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    CPU cores  : 1 @ 2799.998 MHz
    RAM        : 483.2 MiB
    Swap       : 512.0 MiB
    Disk       : 245.8 GiB
    Read       | 9.00 MB/s     (2.2k) | 192.10 MB/s   (3.0k)
    Write      | 9.03 MB/s     (2.2k) | 193.11 MB/s   (3.0k)
    Total      | 18.03 MB/s    (4.5k) | 385.22 MB/s   (6.0k)
    Read       | 827.41 MB/s   (1.6k) | 883.57 MB/s    (862)
    Write      | 871.37 MB/s   (1.7k) | 942.41 MB/s    (920)
    Total      | 1.69 GB/s     (3.3k) | 1.82 GB/s     (1.7k)
    Clouvider       | London, UK (10G)          | 1.40 Gbits/sec  | 381 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.17 Gbits/sec  | 334 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 1.24 Gbits/sec  | 580 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 545 Mbits/sec   | 238 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.98 Gbits/sec  | 965 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 2.71 Gbits/sec  | 947 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 2.34 Gbits/sec  | 567 Mbits/sec
    Performing IPv4 iperf3 send test to Iveloz Telecom (Attempt #1 of 5)...
    SSH connection interrupted, after re-login I see geekbench_claim.url with link to result:
    https://browser.geekbench.com/v5/cpu/9086575
    hosthatch
    hongkong 香港
    1 vCPU 2690 V2
    2GB ram 内存
    20GB 硬盘 Hard Disk NVMe RAID-10
    1gbps bandwidth
    1TB monthly transfer
    Above only applies if paid for 2 years (USD $15 / year)
    #                     v2021-06-05                    #
    Fri Jul 30 20:56:04 EDT 2021
    Processor  : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
    CPU cores  : 1 @ 3000.006 MHz
    RAM        : 1.9 GiB
    Swap       : 128.0 MiB
    Disk       : 19.5 GiB
    Read       | 125.68 MB/s  (31.4k) | 1.53 GB/s    (24.0k)
    Write      | 126.01 MB/s  (31.5k) | 1.54 GB/s    (24.1k)
    Total      | 251.69 MB/s  (62.9k) | 3.08 GB/s    (48.2k)
    Read       | 3.52 GB/s     (6.8k) | 3.46 GB/s     (3.3k)
    Write      | 3.70 GB/s     (7.2k) | 3.69 GB/s     (3.6k)
    Total      | 7.23 GB/s    (14.1k) | 7.15 GB/s     (6.9k)
    Clouvider       | London, UK (10G)          | 500 Mbits/sec   | 31.7 Mbits/sec
    Online.net      | Paris, FR (10G)           | 597 Mbits/sec   | 354 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 513 Mbits/sec   | 356 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 672 Mbits/sec   | 480 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 428 Mbits/sec   | 423 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | busy            | 249 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 499 Mbits/sec   | 478 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 13.2 Mbits/sec
    Single Core     | 673
    Multi Core      | 655
    Full Test       | https://browser.geekbench.com/v5/cpu/9086756
    Thanked by (1)chocolateshirt
    When running qemu on Hetzner AX101, how much difference does -cpu host and -enable-kvm make?
    CPU Host + Enable KVM GB5 Single Core score
    No 110
    Yes 1524
    Note -- using -cpu host without -enable-kvm gives an error:
    root@fsn1 ~ # qemu-system-x86_64 -cpu host -m 8192m -nographic debian-sid-nocloud-amd64-daily.qcow2
    qemu-system-x86_64: CPU model 'host' requires KVM
    root@fsn1 ~ #
    First, without -cpu host and without -enable-kvm
    root@fsn1 ~ # uname -a
    Linux fsn1 5.4.128-1-pve #1 SMP PVE 5.4.128-1 (Wed, 21 Jul 2021 18:32:02 +0200) x86_64 GNU/Linux
    root@fsn1 ~ # cat /etc/debian_version
    10.10
    root@fsn1 ~ #  wget https://cloud.debian.org/images/cloud/sid/daily/latest/debian-sid-nocloud-arm64-daily.qcow2
    root@fsn1 ~ #  tmux
    root@fsn1 ~ # qemu-system-x86_64 -m 8192m -nographic debian-sid-nocloud-amd64-daily.qcow2
    root@debian:~# uname -a
    Linux debian 5.10.0-8-amd64 #1 SMP Debian 5.10.46-3 (2021-07-28) x86_64 GNU/Linux
    root@debian:~# cat /etc/debian_version
    11.0
    root@debian:~# nproc
    1
    root@debian:~# curl -sL yabs.sh | bash
    #                     v2021-06-05                    #
    Sat Jul 31 00:49:31 UTC 2021
    qemu-system-x86_64: Slirp: external icmpv6 not supported yet
    Processor  : Common KVM processor
    CPU cores  : 1 @ 3393.612 MHz
    AES-NI     : ❌ Disabled
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 1.9 GiB
    Less than 2GB of space available. Skipping disk test...
    Clouvider       | London, UK (10G)          | 903 Mbits/sec   | 898 Mbits/sec
    Online.net      | Paris, FR (10G)           | 787 Mbits/sec   | 928 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 918 Mbits/sec   | 933 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 749 Mbits/sec   | 207 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 876 Mbits/sec   | 392 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 340 Mbits/sec   | 478 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 840 Mbits/sec   | 176 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 748 Mbits/sec   | 366 Mbits/sec
    Clouvider       | London, UK (10G)          | 655 Mbits/sec   | 913 Mbits/sec
    Online.net      | Paris, FR (10G)           | 642 Mbits/sec   | 851 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 615 Mbits/sec   | 912 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 639 Mbits/sec   | 400 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 561 Mbits/sec   | 246 Mbits/sec
    Running GB5 benchmark test... *cue elevator music*
    Single Core     | 110
    Multi Core      | 109
    Full Test       | https://browser.geekbench.com/v5/cpu/9086822
    root@debian:~#
    Second, with -cpu host and -enable-kvm
    root@fsn1 ~ # qemu-system-x86_64 -cpu host -enable-kvm -m 8192m -nographic debian-sid-nocloud-amd64-daily.qcow2
    #                     v2021-06-05                    #
    Sat Jul 31 01:37:33 UTC 2021
    CPU cores  : 1 @ 3393.622 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 1.9 GiB
    Clouvider       | London, UK (10G)          | 931 Mbits/sec   | 930 Mbits/sec
    Online.net      | Paris, FR (10G)           | 936 Mbits/sec   | 936 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 936 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 757 Mbits/sec   | 256 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 885 Mbits/sec   | 307 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 144 Mbits/sec   | 530 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 548 Mbits/sec   | 219 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 770 Mbits/sec   | 301 Mbits/sec
    Clouvider       | London, UK (10G)          | 919 Mbits/sec   | 914 Mbits/sec
    Online.net      | Paris, FR (10G)           | 923 Mbits/sec   | 925 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 921 Mbits/sec   | busy
    Clouvider       | NYC, NY, US (10G)         | 872 Mbits/sec   | 356 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 821 Mbits/sec   | 310 Mbits/sec
    Single Core     | 1524
    Multi Core      | 1540
    Full Test       | https://browser.geekbench.com/v5/cpu/9087040
    root@debian:~#
    @Not_Oles said: When running qemu on Hetzner AX101, how much difference does -cpu host and -enable-kvm make?
    Nice trial and results! Very interesting :)
    This is why I always request for CPU passthrough on any newly purchased VMs if it's not enabled by default... Those AES-NI instructions are really essential for some operations. Plus... the less time a client's VM spends processing instructions, the less impact to the load on a host node, so it's a win-win.
  • edited July 2021
    I run yabs inside a screen, so I can leave it anytime without worry..
  • FalzoFalzo Senpai
    would be interesting to also see some middle ground, aka qemu-kvm or similar but with AES-NI enabled (which should be possible with additional settings)... as you said I guess that option alone will make a very huge difference.
    @Not_Oles any chance you can add this too, pretty please ;-)
    Huge Poland KVM (WebHorizon)
    root@pl:~# curl -sL yabs.sh | bash
    #                     v2021-06-05                    #
    Sat Jul 31 05:09:59 EDT 2021
    CPU cores  : 4 @ 3593.248 MHz
    RAM        : 15.3 GiB
    Swap       : 0.0 KiB
    Disk       : 221.5 GiB
    Read       | 341.66 MB/s  (85.4k) | 2.44 GB/s    (38.2k)
    Write      | 342.56 MB/s  (85.6k) | 2.45 GB/s    (38.4k)
    Total      | 684.22 MB/s (171.0k) | 4.90 GB/s    (76.6k)
    Read       | 2.59 GB/s     (5.0k) | 2.75 GB/s     (2.6k)
    Write      | 2.73 GB/s     (5.3k) | 2.93 GB/s     (2.8k)
    Total      | 5.32 GB/s    (10.4k) | 5.69 GB/s     (5.5k)
    Clouvider       | London, UK (10G)          | 923 Mbits/sec   | 886 Mbits/sec
    Online.net      | Paris, FR (10G)           | 925 Mbits/sec   | 860 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | busy
    Biznet          | Jakarta, Indonesia (1G)   | 429 Mbits/sec   | 358 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 780 Mbits/sec   | 460 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 486 Mbits/sec   | 462 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 461 Mbits/sec   | 426 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 375 Mbits/sec   | 230 Mbits/sec
    Clouvider       | London, UK (10G)          | 911 Mbits/sec   | 914 Mbits/sec
    Online.net      | Paris, FR (10G)           | 912 Mbits/sec   | 910 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 912 Mbits/sec   | 917 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 753 Mbits/sec   | 455 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 550 Mbits/sec   | 470 Mbits/sec
    Single Core     | 1282
    Multi Core      | 4210
    Full Test       | https://browser.geekbench.com/v5/cpu/9091736
    Thanked by (2)cybertech Abdullah
  • That is amazing VPSes you have, guys..
  • edited July 2021
    terrahost dedi
    # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #                                                #              Yet-Another-Bench-Script              #
    #                     v2021-06-05                    #
    Sat Jul 31 08:57:32 EDT 2021
    Processor  : Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
    CPU cores  : 4 @ 1692.321 MHz
    RAM        : 7.5 GiB
    Swap       : 7.8 GiB
    Disk       : 450.6 GiB
    Read       | 115.80 MB/s  (28.9k) | 123.61 MB/s   (1.9k)
    Write      | 116.11 MB/s  (29.0k) | 124.26 MB/s   (1.9k)
    Total      | 231.92 MB/s  (57.9k) | 247.87 MB/s   (3.8k)
    Read       | 135.84 MB/s    (265) | 155.59 MB/s    (151)
    Write      | 143.06 MB/s    (279) | 165.95 MB/s    (162)
    Total      | 278.91 MB/s    (544) | 321.54 MB/s    (313)
    Clouvider       | London, UK (10G)          | 925 Mbits/sec   | 917 Mbits/sec
    Online.net      | Paris, FR (10G)           | 917 Mbits/sec   | 874 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 920 Mbits/sec   | 910 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 729 Mbits/sec   | 98.6 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 880 Mbits/sec   | 221 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 841 Mbits/sec   | 314 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 832 Mbits/sec   | 257 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 755 Mbits/sec   | 122 Mbits/sec
    Clouvider       | London, UK (10G)          | 910 Mbits/sec   | 838 Mbits/sec
    Online.net      | Paris, FR (10G)           | 907 Mbits/sec   | 746 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 909 Mbits/sec   | 898 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 864 Mbits/sec   | 177 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 814 Mbits/sec   | 226 Mbits/sec
    Single Core     | 853
    Multi Core      | 2849
    Full Test       | https://browser.geekbench.com/v5/cpu/9095467
    @Falzo said: would be interesting to also see some middle ground, aka qemu-kvm or similar but with AES-NI enabled (which should be possible with additional settings)... as you said I guess that option alone will make a very huge difference.
    Hi @Falzo!
    Here are results with qemu's default processor (as in the first test, above) but now flying the -enable-kvm flag. As might be expected, this third test gives an intermediate result, 1308:
    KVM Status AES Status GB 5 Single Core Score
    Off Off 110
    On Off 1308
    On On 1524
    For anybody trying to understand how KVM could be "off" in test 1, given that the processor model name -- "Common KVM processor" -- literally includes "KVM," please consider that possessing a capability is not the same as actually using the capability. It seems that calling qemu as qemu-kvm-x86_64 requires that root explicitly enable KVM with -enable-kvm in order for KVM to be used. However, when qemu is called simply as kvm then KVM is used automagically if the caller is root but not used if the caller is unprivileged.
    Note that there are additional changes beyond just AES status when switching from the default "Common KVM processor" to -cpu host which is AMD Ryzen 9 5950X 16-Core Processor.
    root@fsn1 ~ # qemu-system-x86_64 -enable-kvm -m 8192m -nographic debian-sid-nocloud-amd64-daily.qcow2
    #                     v2021-06-05                    #
    Sat Jul 31 21:39:44 UTC 2021
    AES-NI     : ❌ Disabled
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 1.9 GiB
    Clouvider       | London, UK (10G)          | 931 Mbits/sec   | 923 Mbits/sec
    Online.net      | Paris, FR (10G)           | 936 Mbits/sec   | 937 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 935 Mbits/sec   | 936 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 761 Mbits/sec   | 269 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 885 Mbits/sec   | 395 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 728 Mbits/sec   | 476 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 843 Mbits/sec   | 293 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 767 Mbits/sec   | 292 Mbits/sec
    Clouvider       | London, UK (10G)          | 919 Mbits/sec   | 910 Mbits/sec
    Online.net      | Paris, FR (10G)           | 924 Mbits/sec   | 924 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 921 Mbits/sec   | 918 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 873 Mbits/sec   | 336 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 829 Mbits/sec   | 332 Mbits/sec
    Single Core     | 1308
    Multi Core      | 1308
    Full Test       | https://browser.geekbench.com/v5/cpu/9101589
    root@debian:~#
    Thanked by (2)Falzo chocolateshirt
    @Mason said: Nice trial and results! Very interesting
    Hey @Mason! Thanks for the kind words! Best wishes from the desert! 👨‍💻​🏜️
  • @Not_Oles thanks, interesting indeed, esp. because the gap is much smaller with that setting and AES still is disabled. I'd guess KVM+AES then comes really close to full host passthru
    Just a mini-update towards the Alwyzon Performance Server line: instead of Xeon® E-2174G (no longer sold), you might now get a Xeon® E-2244G (newer model) delivered instead. But no worries, those are at least as beefy as the E-2174G. 🥳
    — Michael
    #                     v2021-06-05                    #
    Mon Aug  2 08:54:03 UTC 2021
    Processor  : Intel(R) Xeon(R) E-2244G CPU @ 3.80GHz
    CPU cores  : 2 @ 3791.998 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 400.0 GiB
    Read       | 191.84 MB/s  (47.9k) | 934.60 MB/s  (14.6k)
    Write      | 192.35 MB/s  (48.0k) | 939.52 MB/s  (14.6k)
    Total      | 384.19 MB/s  (96.0k) | 1.87 GB/s    (29.2k)
    Read       | 1.35 GB/s     (2.6k) | 1.19 GB/s     (1.1k)
    Write      | 1.43 GB/s     (2.7k) | 1.27 GB/s     (1.2k)
    Total      | 2.79 GB/s     (5.4k) | 2.47 GB/s     (2.4k)
    Clouvider       | London, UK (10G)          | 929 Mbits/sec   | 899 Mbits/sec
    Online.net      | Paris, FR (10G)           | 929 Mbits/sec   | 888 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 926 Mbits/sec   | 894 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 447 Mbits/sec   | 357 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 677 Mbits/sec   | 841 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 605 Mbits/sec   | 744 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 454 Mbits/sec   | 694 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 279 Mbits/sec   | 618 Mbits/sec
    Clouvider       | London, UK (10G)          | 918 Mbits/sec   | 764 Mbits/sec
    Online.net      | Paris, FR (10G)           | 910 Mbits/sec   | 719 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 912 Mbits/sec   | 772 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 701 Mbits/sec   | 822 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 504 Mbits/sec   | 773 Mbits/sec
    Single Core     | 5785
    Multi Core      | 10455
    Full Test       | https://browser.geekbench.com/v4/cpu/16288009
    Single Core     | 1234
    Multi Core      | 2333
    Full Test       | https://browser.geekbench.com/v5/cpu/9123605
    Picked up a few UK VMs to benchmark as I'm looking for a new home for a few smaller projects.
    VM Specialist
    #                     v2021-06-05                    #
    Mon 02 Aug 2021 06:02:19 AM EDT
    Processor  : Intel(R) Xeon(R) E-2276G CPU @ 3.80GHz
    CPU cores  : 1 @ 3792.000 MHz
    RAM        : 987.3 MiB
    Swap       : 0.0 KiB
    Disk       : 13.8 GiB
    Read       | 508.09 MB/s (127.0k) | 3.90 GB/s    (61.0k)
    Write      | 509.44 MB/s (127.3k) | 3.93 GB/s    (61.4k)
    Total      | 1.01 GB/s   (254.3k) | 7.83 GB/s   (122.4k)
    Read       | 5.19 GB/s    (10.1k) | 5.57 GB/s     (5.4k)
    Write      | 5.47 GB/s    (10.6k) | 5.94 GB/s     (5.8k)
    Total      | 10.67 GB/s   (20.8k) | 11.52 GB/s   (11.2k)
    Clouvider       | London, UK (10G)          | 9.25 Gbits/sec  | 8.16 Gbits/sec
    Online.net      | Paris, FR (10G)           | 8.38 Gbits/sec  | busy
    WorldStream     | The Netherlands (10G)     | 8.90 Gbits/sec  | 8.32 Gbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 867 Mbits/sec   | 101 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.20 Gbits/sec  | 2.18 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 2.38 Gbits/sec  | 1.98 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.30 Gbits/sec  | 1.22 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 241 Mbits/sec   | 972 Mbits/sec
    Clouvider       | London, UK (10G)          | 9.14 Gbits/sec  | 8.75 Gbits/sec
    Online.net      | Paris, FR (10G)           | 7.77 Gbits/sec  | 6.74 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 9.17 Gbits/sec  | 4.74 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.33 Gbits/sec  | 1.80 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.31 Gbits/sec  | 1.20 Gbits/sec
    Single Core     | 1147
    Multi Core      | 1151
    Full Test       | https://browser.geekbench.com/v5/cpu/9124666
    OVHcloud
    #                     v2021-06-05                    #
    Mon 02 Aug 2021 12:19:40 PM UTC
    Processor  : Intel Core Processor (Haswell, no TSX)
    CPU cores  : 1 @ 2394.428 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 39.3 GiB
    Read       | 40.03 MB/s   (10.0k) | 642.00 MB/s  (10.0k)
    Write      | 40.12 MB/s   (10.0k) | 645.38 MB/s  (10.0k)
    Total      | 80.16 MB/s   (20.0k) | 1.28 GB/s    (20.1k)
    Read       | 548.71 MB/s   (1.0k) | 541.65 MB/s    (528)
    Write      | 577.87 MB/s   (1.1k) | 577.72 MB/s    (564)
    Total      | 1.12 GB/s     (2.1k) | 1.11 GB/s     (1.0k)
    Clouvider       | London, UK (10G)          | 246 Mbits/sec   | 246 Mbits/sec
    Online.net      | Paris, FR (10G)           | 246 Mbits/sec   | 245 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 244 Mbits/sec   | 245 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 136 Mbits/sec   | 15.3 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 238 Mbits/sec   | 239 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 230 Mbits/sec   | 229 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 227 Mbits/sec   | 229 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 210 Mbits/sec   | 216 Mbits/sec
    Single Core     | 609
    Multi Core      | 606
    Full Test       | https://browser.geekbench.com/v5/cpu/9126855
    Nexus Bytes
    #                     v2021-06-05                    #
    Mon 02 Aug 2021 08:43:20 AM EDT
    CPU cores  : 1 @ 3493.438 MHz
    RAM        : 987.3 MiB
    Swap       : 0.0 KiB
    Disk       : 14.7 GiB
    Read       | 188.83 MB/s  (47.2k) | 1.86 GB/s    (29.2k)
    Write      | 189.33 MB/s  (47.3k) | 1.87 GB/s    (29.3k)
    Total      | 378.17 MB/s  (94.5k) | 3.74 GB/s    (58.5k)
    Read       | 3.71 GB/s     (7.2k) | 3.54 GB/s     (3.4k)
    Write      | 3.91 GB/s     (7.6k) | 3.77 GB/s     (3.6k)
    Total      | 7.62 GB/s    (14.8k) | 7.31 GB/s     (7.1k)
    Clouvider       | London, UK (10G)          | 929 Mbits/sec   | 940 Mbits/sec
    Online.net      | Paris, FR (10G)           | 916 Mbits/sec   | 935 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 920 Mbits/sec   | 939 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 444 Mbits/sec   | 145 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 844 Mbits/sec   | 384 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 577 Mbits/sec   | 479 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 442 Mbits/sec   | 173 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 319 Mbits/sec   | 149 Mbits/sec
    Clouvider       | London, UK (10G)          | 924 Mbits/sec   | 927 Mbits/sec
    Online.net      | Paris, FR (10G)           | 918 Mbits/sec   | 915 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 925 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 812 Mbits/sec   | 302 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 478 Mbits/sec   | 180 Mbits/sec
    Single Core     | 1217
    Multi Core      | 1195
    Full Test       | https://browser.geekbench.com/v5/cpu/9127155
    Nice performance throughout, but will probably hold onto the VM Specialist one - kudos @Mr_Tom
    Thanked by (2)Mr_Tom cybertech
    piximg image hosting
  • NexusBytes VPS-6G Ryzen
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 6 @ 3792.872 MHz
    RAM        : 5.8 GiB
    Swap       : 0.0 KiB
    Disk       : 88.5 GiB
    Read       | 352.17 MB/s  (88.0k) | 3.71 GB/s    (58.0k)
    Write      | 353.10 MB/s  (88.2k) | 3.73 GB/s    (58.3k)
    Total      | 705.28 MB/s (176.3k) | 7.44 GB/s   (116.4k)
    Read       | 4.33 GB/s     (8.4k) | 4.21 GB/s     (4.1k)
    Write      | 4.56 GB/s     (8.9k) | 4.50 GB/s     (4.3k)
    Total      | 8.90 GB/s    (17.3k) | 8.71 GB/s     (8.5k)
    Clouvider       | London, UK (10G)          | 318 Mbits/sec   | 249 Mbits/sec
    Online.net      | Paris, FR (10G)           | 235 Mbits/sec   | 755 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 139 Mbits/sec   | 419 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 635 Mbits/sec   | 452 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 431 Mbits/sec   | 301 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 16.4 Mbits/sec  | 57.8 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 624 Mbits/sec   | 411 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 614 Kbits/sec
    Single Core     | 1333
    Multi Core      | 6131
    Full Test       | https://browser.geekbench.com/v5/cpu/9134126
  • Entrybytes Entry-8G
    UK node
    Processor  : Intel(R) Xeon(R) CPU E5-2630L v2 @ 2.40GHz
    CPU cores  : 4 @ 2399.996 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 78.7 GiB
    Read       | 171.05 MB/s  (42.7k) | 1.87 GB/s    (29.2k)
    Write      | 171.50 MB/s  (42.8k) | 1.88 GB/s    (29.4k)
    Total      | 342.55 MB/s  (85.6k) | 3.75 GB/s    (58.7k)
    Read       | 4.16 GB/s     (8.1k) | 5.54 GB/s     (5.4k)
    Write      | 4.38 GB/s     (8.5k) | 5.91 GB/s     (5.7k)
    Total      | 8.54 GB/s    (16.6k) | 11.45 GB/s   (11.1k)
    Clouvider       | London, UK (10G)          | 947 Mbits/sec   | 933 Mbits/sec
    Online.net      | Paris, FR (10G)           | 939 Mbits/sec   | 930 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 401 Mbits/sec   | 78.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 759 Mbits/sec   | 404 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 25.0 Mbits/sec  | 100 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 349 Mbits/sec   | 180 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 180 Mbits/sec   | 205 Mbits/sec
    Single Core     | 484
    Multi Core      | 1825
    Full Test       | https://browser.geekbench.com/v5/cpu/9134169
    NL node
    Processor  : Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz
    CPU cores  : 4 @ 2095.162 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 78.7 GiB
    Read       | 141.89 MB/s  (35.4k) | 1.85 GB/s    (29.0k)
    Write      | 142.27 MB/s  (35.5k) | 1.86 GB/s    (29.1k)
    Total      | 284.16 MB/s  (71.0k) | 3.72 GB/s    (58.2k)
    Read       | 4.17 GB/s     (8.1k) | 4.30 GB/s     (4.2k)
    Write      | 4.39 GB/s     (8.5k) | 4.59 GB/s     (4.4k)
    Total      | 8.57 GB/s    (16.7k) | 8.90 GB/s     (8.6k)
    Clouvider       | London, UK (10G)          | 971 Mbits/sec   | 949 Mbits/sec
    Online.net      | Paris, FR (10G)           | 981 Mbits/sec   | 948 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 979 Mbits/sec   | 952 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 272 Mbits/sec   | 63.0 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 429 Mbits/sec   | 885 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 24.0 Mbits/sec  | 234 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 308 Mbits/sec   | 505 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 229 Mbits/sec   | 246 Mbits/sec
    Single Core     | 551
    Multi Core      | 2016
    Full Test       | https://browser.geekbench.com/v5/cpu/9134170
    Thanked by (2)cybertech seriesn
