Contabo 400GB free SSD if you order today
    edited February 2022
    That is quite awesome :D Thanks for sharing!
  • TheDPTheDP OGSenpai
    How’s the performance like for the SSDs?
    Capped I/O?
    Capped I/O?
    You can open a ticket to lift the cap iirc :)
    Capped I/O?
    root@vmi714128:~# curl -sL yabs.sh | bash -s -- -r
    #                     v2021-12-28                    #
    Fri 11 Feb 2022 02:45:18 PM CET
    Processor  : AMD EPYC 7282 16-Core Processor
    CPU cores  : 4 @ 2794.746 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 7.8 GiB
    Swap       : 2.0 GiB
    Disk       : 392.7 GiB
    Read       | 5.30 MB/s     (1.3k) | 64.65 MB/s    (1.0k)
    Write      | 5.32 MB/s     (1.3k) | 65.04 MB/s    (1.0k)
    Total      | 10.62 MB/s    (2.6k) | 129.70 MB/s   (2.0k)
    Read       | 127.64 MB/s    (249) | 97.70 MB/s      (95)
    Write      | 134.43 MB/s    (262) | 104.21 MB/s    (101)
    Total      | 262.07 MB/s    (511) | 201.92 MB/s    (196)
    Clouvider       | London, UK (10G)          | 188 Mbits/sec   | 198 Mbits/sec
    Online.net      | Paris, FR (10G)           | 189 Mbits/sec   | 196 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 185 Mbits/sec   | 189 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 535
    Multi Core      | 929
    Full Test       | https://browser.geekbench.com/v5/cpu/12711249
  • Of course it comes a deal like that when I just terminated my 2 VPSes there hehe.
    Not sure if I would need the disk, that would be the only thing I would go back for hehe.
    That's the only thing why I bought it haha, and that's the point of this promo. I've raised a ticket to remove the I/O limit, and will yabs it again.
    Hmm..a vps which I don't need with DOUBLE disk..hmm..
    same here, it's only the disk space that makes it a bit more interesting. luckily the IO limitations seems to put it quite into the range of just somewhat cached HDD and the geekbench is even worse. 500 single score isn't Epyc worthy and scaling to 900 on a 4 core VPS? nah. pass.
    thanks for the heads up but hard pass
    Thats why I moved, got VPS with single core score higher then the 4 cores.
    Not to mention the nice CPU steal and software interrupt so the only only thing was the amount of diskspace.
    I might bite on Hetzner Nextcloud/Storage though. Some people made me want to give it a try :)
    @Amadex said:
    @TheDP said:
    Similar apart from I get a lot higher Geekbench scores;
    CPU cores  : 4 @ 2794.748 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 392.7 GiB
    Read       | 5.29 MB/s     (1.3k) | 64.02 MB/s    (1.0k)
    Write      | 5.31 MB/s     (1.3k) | 64.43 MB/s    (1.0k)
    Total      | 10.61 MB/s    (2.6k) | 128.45 MB/s   (2.0k)
    Read       | 127.62 MB/s    (249) | 97.24 MB/s      (94)
    Write      | 134.40 MB/s    (262) | 103.72 MB/s    (101)
    Total      | 262.02 MB/s    (511) | 200.97 MB/s    (195)
    Clouvider       | London, UK (10G)          | 193 Mbits/sec   | 200 Mbits/sec
    Online.net      | Paris, FR (10G)           | 192 Mbits/sec   | 200 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 200 Mbits/sec
    WebHorizon      | Singapore (400M)          | 176 Mbits/sec   | 186 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 186 Mbits/sec   | 195 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 174 Mbits/sec   | 189 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 178 Mbits/sec   | 187 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 170 Mbits/sec   | 183 Mbits/sec
    Single Core     | 1009
    Multi Core      | 3793
    Full Test       | https://browser.geekbench.com/v5/cpu/12712270
    @ialexpw ah that happens with many providers... I'm requestiong to them that they move me to another node and problem will be solved. Will yabs it again.
  • @Falzo @Amadex what is the cancellation policy? 1 month or more for longer contract periods?
    thanks in advance.
    thanks in advance.
    It's prepaid, you are not under contract (like on e.g. netcup).
    Thanked by (1)ehab
  • @Amadex so a cancel button gives that "At end of billing period option" ? or must be some process?
    Minimum cancellation notice:
    None (pre-paid) or 4 weeks (post-paid)
    So, just let it expire if you don't need it.
    Thanked by (2)ehab Ympker
    @Amadex said:
    Capped I/O?
    > #              Yet-Another-Bench-Script              #
    > #                     v2021-12-28                    #
    > # https://github.com/masonr/yet-another-bench-script #
    > Basic System Information:
    > AES-NI     : ✔ Enabled
    > RAM        : 7.8 GiB
    > Swap       : 2.0 GiB
    > Disk       : 392.7 GiB
    > fio Disk Speed Tests (Mixed R/W 50/50):
    > Block Size | 4k            (IOPS) | 64k           (IOPS)
    > Block Size | 512k          (IOPS) | 1m            (IOPS)
    > iperf3 Network Speed Tests (IPv4):
    > Test            | Value
    > Single Core     | 535
    > Multi Core      | 929
    Poor performance, with 4 hdd's in raid 10 I get 180-200mb/s
    What a great deal especially for Singapore.
    Thanked by (3)Falzo Ympker chimichurri
    nothing is special if not like MikeA's specials.... I miss my 32GB
    Not sure if I would need the disk, that would be the only thing I would go back for hehe.> @ialexpw said:
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 392.7 GiB
    Single Core     | 1009
    Multi Core      | 3793
    You got lucky, mine was also good in the beginning if i remember correctly.
    Then started to drop as they seem to make use of the hardware as possible.
    As I know, Contabo overbooks there machines.
  • It's a pretty good offer, that extra disk space is really tempting. I was lucky enough to have my both servers hosted on good nodes (no cpu steal) and without having the I/O rates reverted as I've read about in some comments. Wonder if I should push my luck once more.
  • The 400gb is the 200gb that's already usually part of the plan, plus another 200gb added amirite? So only the extra 200gb is "free". Anyway it still seems like a pass given the persistent crummy benches among other things. All in all I'm happy with a smaller ssd (50gb is really plenty) and a much bigger disk of spinning rust.
    New disk speed yabs, and I'm waiting for some CPU power in work-days.. It's Sunday and I guess their staff is not working.
    For 4.99€ / mo. Nice.
    #                     v2021-12-28                    #
    Sun 13 Feb 2022 01:33:59 PM CET
    RAM        : 7.8 GiB
    Swap       : 2.0 GiB
    Disk       : 392.7 GiB
    Read       | 5.30 MB/s     (1.3k) | 64.17 MB/s    (1.0k)
    Write      | 5.32 MB/s     (1.3k) | 64.59 MB/s    (1.0k)
    Total      | 10.62 MB/s    (2.6k) | 128.77 MB/s   (2.0k)
    Read       | 510.08 MB/s    (996) | 414.70 MB/s    (404)
    Write      | 537.18 MB/s   (1.0k) | 442.32 MB/s    (431)
    Total      | 1.04 GB/s     (2.0k) | 857.02 MB/s    (835)
    Single Core     | 631
    Multi Core      | 1457
    Full Test       | https://browser.geekbench.com/v5/cpu/12754041
    > #                     v2021-12-28                    #
    > AES-NI     : ✔ Enabled
    > RAM        : 7.8 GiB
    > Swap       : 2.0 GiB
    > Disk       : 392.7 GiB
    > Test            | Value
    > Single Core     | 631
    > Multi Core      | 1457
    Don't expect too much from Contabo. It's known that they are overbooking there Systems.
  • That is a pretty low benchmark right? I have lost track of this stuff.
    Yeah, disk is hard capped and you can get unlucky with overloaded processor
  • Thanks. I'd wonder what to do with a product like this. I wonder how much ram pressure there is. If the iops cap means they are really able to deliver 1k iops consistently then I guess it is better than a dedicated HDD. But there is also the cpu. Hmm.
  • Is Contabo uptime high? Should I use it in production?
    Read a lot about Contabe but I haven't give them a try.
