Of course it comes a deal like that when I just terminated my 2 VPSes there hehe.
Not sure if I would need the disk, that would be the only thing I would go back for hehe.
That's the only thing why I bought it haha, and that's the point of this promo. I've raised a ticket to remove the I/O limit, and will yabs it again.
@Ympker said:
Hmm..a vps which I don't need with DOUBLE disk..hmm..
same here, it's only the disk space that makes it a bit more interesting. luckily the IO limitations seems to put it quite into the range of just somewhat cached HDD and the geekbench is even worse. 500 single score isn't Epyc worthy and scaling to 900 on a 4 core VPS? nah. pass.
Thats why I moved, got VPS with single core score higher then the 4 cores.
Not to mention the nice CPU steal and software interrupt so the only only thing was the amount of diskspace.
I might bite on Hetzner Nextcloud/Storage though. Some people made me want to give it a try
@ialexpw ah that happens with many providers... I'm requestiong to them that they move me to another node and problem will be solved. Will yabs it again.
Not sure if I would need the disk, that would be the only thing I would go back for hehe.> @ialexpw said:
@Amadex said: @ialexpw ah that happens with many providers... I'm requestiong to them that they move me to another node and problem will be solved. Will yabs it again.
It's a pretty good offer, that extra disk space is really tempting. I was lucky enough to have my both servers hosted on good nodes (no cpu steal) and without having the I/O rates reverted as I've read about in some comments. Wonder if I should push my luck once more.
The 400gb is the 200gb that's already usually part of the plan, plus another 200gb added amirite? So only the extra 200gb is "free". Anyway it still seems like a pass given the persistent crummy benches among other things. All in all I'm happy with a smaller ssd (50gb is really plenty) and a much bigger disk of spinning rust.
@Amadex said:
New disk speed yabs, and I'm waiting for some CPU power in work-days.. It's Sunday and I guess their staff is not working.
For 4.99€ / mo. Nice.
Thanks. I'd wonder what to do with a product like this. I wonder how much ram pressure there is. If the iops cap means they are really able to deliver 1k iops consistently then I guess it is better than a dedicated HDD. But there is also the cpu. Hmm.
That is quite awesome
Thanks for sharing!
How’s the performance like for the SSDs?
Capped I/O?
You can open a ticket to lift the cap iirc
thanks for the heads up but hard pass
Similar apart from I get a lot higher Geekbench scores;
@Falzo @Amadex what is the cancellation policy? 1 month or more for longer contract periods?
thanks in advance.
It's prepaid, you are not under contract (like on e.g. netcup).
@Amadex so a cancel button gives that "At end of billing period option" ? or must be some process?
Minimum cancellation notice:
None (pre-paid) or 4 weeks (post-paid)
So, just let it expire if you don't need it.
Poor performance, with 4 hdd's in raid 10 I get 180-200mb/s
What a great deal especially for Singapore.
ExtraVM - KVM NVMe VPS in USA, EU, APAC -|- RackColo - Find Colo
Discord: mikea
nothing is special if not like MikeA's specials.... I miss my 32GB
You got lucky, mine was also good in the beginning if i remember correctly.
Then started to drop as they seem to make use of the hardware as possible.
As I know, Contabo overbooks there machines.
Don't expect too much from Contabo. It's known that they are overbooking there Systems.
That is a pretty low benchmark right? I have lost track of this stuff.
Yeah, disk is hard capped and you can get unlucky with overloaded processor
Is Contabo uptime high? Should I use it in production?
Read a lot about Contabe but I haven't give them a try.
