145791015
  • NeoonNeoon OGSenpai
    Fremont is still down, due to complications, the Node isn't booting.
    After chassis swap, with the old drives, one Drive was non longer reported and has been replaced.
    No ETA right now, they trying to get the Node back online, Raid 10 looks fine after drive replacement.
    Fremont is back Online, CPU and Memory Upgraded.
    Raid 10 still in sync, I/O performance will be a bit lower until synced up.
    Thanked by (2)bdl Ganonk
    Could you check if the network config on the node broke somehow? DHCP and IPv6 autoconfig don't work for me.
    I can get IPv4 to work if I configure static addresses but for IPv6 I don't get beyond the gateway:
    mtr --report --report-wide 2001:470:20::2
    Start: Mon Jun  6 16:07:35 2022
    HOST: xxxxxx Loss%   Snt   Last   Avg  Best  Wrst StDev
      1.|-- gateway             0.0%    10    0.2   0.2   0.2   0.2   0.0
      2.|-- ???                100.0    10    0.0   0.0   0.0   0.0   0.0
    Should be fixed.
    Should be fixed.
    Thanks for looking into this! Autoconf works now but still no cigar:
    # ping6 2620:fe::fe
    PING 2620:fe::fe(2620:fe::fe) 56 data bytes
    ^C
    --- 2620:fe::fe ping statistics ---
    13 packets transmitted, 0 received, 100% packet loss, time 11999ms
    Should be fixed.
    # ping6 2620:fe::fe
    ^C
    Fixed, sorry for the issues.
    No worries, thanks for maintaining this service for free!
  • DE node has been renewed again :3
  • DE node reborn again? :o
    edited June 2022
    No, likely the machine was suspended due to no payment, and this has been done yesterday. this happened several times.
    As said before, we don't do any new deployments, I will starting removing DE.
    Thanked by (1)Ganonk
    Norway will be upgraded to 32GB Memory on Friday at 11:00 CEST.
    Expected Downtime about 5-10 minutes.
    Thanked by (2)flips Ganonk
    The Panel is currently broken, no ETA, working on it.
    Fixed, had some encoding issues after upgrading the database server.
    If you still see your Server status as unknown, please lemme now and I take a look.
  • Hi my Norway issn't getting his ipv6 address anymore.
    also reboot doesnt fix it.
    We had a maintenance on NO, after the boot radvd did not came up properly, should be fixed.
    Thanked by (1)ThomasP
    Yep working again thank you :)
    NO and FM have been restocked, NL will follow later.
    As stuff got switched to cloud-init, the images have been updated too.
    If I choose 2GB ram, it says that the memory configuration is invalid
    2 GB ram only DE node
    Uh, we actually do input validation.
    Yea I changed the 2GB option, however I forgot to edit the actual validation.
    Will fix it.
    Will fix it.
    also please look at my LET application, please don't forget this time xd
    Will fix it.
    Dude, you put the request in on a weekend!
    Don't be a dick.
    Thanked by (3)ralf Ganonk Ouji
  • MasonMason AdministratorOG
    Don't be a dick.
    No excuses. Also I demand an SLA and refunds for extended outages, I accept XMR and DOGE. A detailed RFO report needs to also be produced for any outages > 5 minutes. Kthxbai
    Will fix it.
    Don't be a dick.
    Thank you for setting up, and sorry didn't mean of being rude
    550b8883e215cc0ff53ab90f7fa99089e18f0186
    For hosting a WP website (personal and tech blog)
    Contact me at: +1 (509) 606-3569 or [email protected]
    Deployed.
  • 19b65a1be364e52d3398939deb9c492a13587965
    For create V2Ray Server and test some applications. Thanks you.
    Thanks, no.
    Thanked by (5)_MS_ Advin Ganonk Erisa tototo
  • AdvinAdvin Hosting Provider
    ee1074d5ff673b3413a9993eaf9553f841b8ccd0
    Interested in playing around with it. I'll most likely be running a couple of very small websites, and maybe also running an uptime monitor along with it :)
    maybe Neoon has something from advinservers and him reading this is like :
