@Daevien said:
Failures from Hetrix from 4 locations, tried from multiple IPs & billing system failing to be able to connect even to the server before I even mentioned it here.
Not sure how you are seeing it up via VPN @lesuser unless you just tried vpn exactly when a reboot or something started to clear it
Only home page is showing up on VPN. When I click on other pages then it says connection timed out. I think this is why hetrixtools and other website is also saying it is online. I am not sure if this is due to cache or something else because I am using CloudFlare cache. But other pages should also come if home page is coming from cache.
*Due to the extreme ticket volumes we've been receiving recently, your renewal price will be increased if you contribute to the excessive ticket load by creating an unnecessary ticket. Of course, this is at our discretion and interpreted by us, so if you disagree, you can always cancel your service properly per our policies to avoid a renewal at the adjusted rate. Price increase will be +$5 annually per unnecessary ticket.
We will also do this if you spam this thread with your order ID asking for something outside of an activation request, or if you post your ticket ID (unless requested by us.)
Thank you, I didn't notice them, I'd better wait for them to deal with...
@lesuser said: When I used downforeveryoneorjustme.com then it also says my website in online
You sure you are testing correct URL in HetrixTools?
You sure you are not testing Cloudflare (or any other caching-proxy) and Always On and it just spits out static page?
Maybe you are using ping endpoint in HT and it just ICMP ping machine... not test HTTP connectivity (nginx/apache/w/e you running there)?
Yea CloudFlare cache is on so may be it was picking it from there.
Anyone again facing issue with NYCB030? My website has become extremely slow all of a sudden. It's like I am back in dial up internet era.
Why did you take the REDEPLOY button off ? If there is a problem, the customer can use this button to reset it according to the situation.
Yeah then half the customers use it while a node is having issues and it cause it to break further, then they post "it has been down for weeks" instead of a day.
I was just about to ask about Cloudflare.
@Daevien said:
Well, it's back for now at least. Some nasty messages though waiting for me when i logged in lol
watchdog: BUG: soft lockup - CPU#2 stuck for 17538s!
watchdog: BUG: soft lockup - CPU#0 stuck for 17538s!
watchdog: BUG: soft lockup - CPU#1 stuck for 17544s!
It never went offline some just locked up some didn't, I was able to fix it without a reboot.
@Astro@KuYeHQ@j0rmo Here is the VirMach comment regarding instructions on how to get a free test VM in APAC region
@VirMach said:
We need around 200 people from APAC region, so China, Australia, Japan, Singapore, and so on. To test out Japan/Singapore/Hong Kong for our 2nd DC partner there any compare it to existing Tokyo.
So basically minimum requirements are you have a service in Tokyo with us already, and willing to provide feedback. Any ideas on how we should pick out people and if anyone is interested in getting on the shortlist of people willing to actually provide feedback on which network works out better for you, DM me your email. Only include your email. I'll add it to a list, grab user IDs, add a note to your account with your LES user ID, and then you'll probably get a welcome email of a duplicate of one of your services in Tokyo for about a month.
oh, long time no see guys
tyo039 tester is comming
i have already send a message only include my email
btw, i know something happened recently, im mjj from china too
@FrankZ said: I was kind of hoping it was down to add IPv6, but no luck there.
It's already set up I just need to click a lot of buttons. I can't wait until we do it all manually or semi-manually and then SVM finally releases the next version with API.
So, I wonder if you would compensate for the downtime by returning the balance?
Yeah node is back online
hi
@VirMach Can you fix Ticket #656937 for me?
Chad, don't you read?
Ontario Dildo Inspector
@Flying_Chinaman rains on @cnencc 's first comment on LES
It is truly a cruel, cruel world. /s
Always On
and it just spits outstatic
page?Maybe you are using
ping
endpoint in HT and it just ICMP ping machine... not test HTTP connectivity (nginx/apache/w/e you running there)?Haven't bought a single service in VirMach Great Ryzen 2022 - 2023 Flash Sale.
EDIT
Issue seems to be solved now.
@VirMach
Node Name DALZ007 Down
APAC region - China,
I put a timer script on my home router to test your Tokyo network.
It automatically downloads 100MiB of data every hour.
If the new DC2 in APAC needs to do this kind of test, I can help.
The log is as follows
oh, virmach, i think you can't lack me for testing the server in asia pacific, a mjj from China
Oh hey I'd love for you to test it actually, I remember your name.
Thanks! I'm up for a bit of testing if @VirMach still has a spot.
Team push-ups!
@Astro @KuYeHQ @j0rmo Here is the VirMach comment regarding instructions on how to get a free test VM in APAC region
Sent the message!
@VirMach
Team push-ups!
today i got a renew invoice using credit.
at first i got horney thinking it was my 2-GTI but then it was like yoursunny replies when he runies any boner.
Amsterdam down
But looks like upstream issue as xTom speedtest/lg is not loading either
@VirMach, Amsterdam is off. Operation Timed Out After 90001 Milliseconds With 0 Bytes Received
What nodes are you guys on, seems to be 28 for me in AMS?
Whole Amsterdam is offline and it's not VirMach (stricte) issue - seems like whole datacenter is gone :P
We back bois
YOU BROKE IT!
AMS was off line 40 Minutes for me. So @Jab is a pretty good monitoring service.
