why do I have kernel version 4.19.0 in Debian 11, while in jmaxwell's YABS log there is 5.4.0 in Ubuntu 20.04? I always thought that for OpenVZ all VMs have the same kernel version equal to host machine kernel
do we really need installed and running apache2 and exim4 in Debian 11 template for that NAT VPS?
Don t know exactly why , maybe YABS error??? from what I remember, only on centos 6 was the kernel to be the same, from openvz 7 it should not be the same
With this comes the default templates from the virtualizor
@Calin said:
Hello , yes node running on powersave mode
Regards,
Calin
you would be able to get a better user experience if you switched that.
which would in turn mean higher retention of your clients
which means more sales.
which is more $$$
Regards,
Calin
which is more $$$
Yes , it s on progress for move on maximum performance on next days maximum two week. For now it s on power save mode because electricity it s very expensive , about 0.65$ per KWh and this server usage 200w on maximum performance.
Hello @yoursunny unfortunity on this type of service no , in the next days and IPv6 will work, unfortunately it's the problem with the routing that I don't understand exactly why it's happening
Regards,
Calin
I need port 443 so that I can request TLS certificates with ACME client.
IPv6 routing not working means the service is not usable to me.
You should not have delivered the service before it's fully working.
Hence, I'm asking you to extend service time starting from the date it becomes fully working.
If you refuse, I may be forced to ask for refund.
Hello @yoursunny thanks for informations , yes that it s true , https://docs.datadoghq.com/security_platform/default_rules/cis-docker-1.2.0-5.7/ i m view here more informations about this
future VPSs will be delivered with other ports , for any dissatisfaction you can open a ticket and I can move you to other ports
Regards,
Calin
@Calin will there be ipv6 connectivity?
Hello @dosai in next days most probality starting working , i m have little problems right now with IPv6 routing
Regards,
Calin
Invoice #669
can confirm for my VPS
@Callin two questions:
Invoice #673 pls
did anyone receive correct amount of extra ram? It should be 896mb but I got only 768mb
same
Same for me too
Why?
Seems like problems with math
Hello everyone , done i m fixed this problems
Regards,
Calin
Invoice #675
Website: thomassen.sh
why is the disk so slow? i have usb2 flash drives faster then this.
Hello it s possible give me a yabs??
Regards,
Calin
Im generating a report now, but it also looks like your running your node on powersave mode? the clock speeds are very low for the cpu.
Regards,
Calin
which is more $$$
'''fio Disk Speed Tests (Mixed R/W 50/50):
People torrenting like crazy on a raid 0 array, maybe?
I know, i just wanted too be part of the inevitable dumpster fire too...
Regards,
Calin
Given the services are not delivered as described, will you extend next invoice date to credit for the days that the service is not fully working?
HostBrr aff best VPS.
We are impotent.
Regards,
Calin
We are impotent.
Hello @yoursunny i m understand you problems , please open ticket on website and it s possible opened you port 443
Regards,
Calin
Im gratefull that you did not accept my offer. Thank you
Hello @emperor what do you mean?
it means you let him down. and it was in his favor.
Hello neighbors! ^^ How's life going?
