iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
1356719
  • CalinCalin Hosting Provider
    edited November 2022
    Hello @yoursunny thanks for informations , yes that it s true , https://docs.datadoghq.com/security_platform/default_rules/cis-docker-1.2.0-5.7/ i m view here more informations about this
    future VPSs will be delivered with other ports , for any dissatisfaction you can open a ticket and I can move you to other ports
    Regards,
    Calin
  • @Calin will there be ipv6 connectivity?
    Hello @dosai in next days most probality starting working , i m have little problems right now with IPv6 routing
    Regards,
    Calin
    Thanked by (2)dosai shadowban
  • Invoice #669
  • @Calin said:
    Hello i m finish delivery all vps , and I gave extra ram memory to everyone who left the invoice number
    can confirm for my VPS
    @Callin two questions:
    1. why do I have kernel version 4.19.0 in Debian 11, while in jmaxwell's YABS log there is 5.4.0 in Ubuntu 20.04? I always thought that for OpenVZ all VMs have the same kernel version equal to host machine kernel
    2. do we really need installed and running apache2 and exim4 in Debian 11 template for that NAT VPS?
  • Invoice #673 pls
  • did anyone receive correct amount of extra ram? It should be 896mb but I got only 768mb
    same
    Same for me too
    Why?
    Seems like problems with math :)
    Hello everyone , done i m fixed this problems
    Regards,
    Calin
    1. Don t know exactly why , maybe YABS error??? from what I remember, only on centos 6 was the kernel to be the same, from openvz 7 it should not be the same
    2. With this comes the default templates from the virtualizor
  • why is the disk so slow? i have usb2 flash drives faster then this.
    Hello it s possible give me a yabs??
    Regards,
    Calin
  • Im generating a report now, but it also looks like your running your node on powersave mode? the clock speeds are very low for the cpu.
    Hello , yes node running on powersave mode
    Regards,
    Calin
    Regards,
    Calin
    you would be able to get a better user experience if you switched that.
    which would in turn mean higher retention of your clients
    which means more sales.
    which is more $$$
  • edited November 2022
    Regards,
    Calin
    '''fio Disk Speed Tests (Mixed R/W 50/50):
    Read 657.00 KB/s (164) 7.50 MB/s (117)
    Write 686.00 KB/s (171) 7.87 MB/s (122)
    Total 1.34 MB/s (335) 15.37 MB/s (239)
    Read 11.28 MB/s (22) 12.28 MB/s (12)
    Write 12.46 MB/s (24) 13.50 MB/s (13)
    Total 23.75 MB/s (46) 25.79 MB/s (25)'''
  • @jugganuts said: why is the disk so slow?
    People torrenting like crazy on a raid 0 array, maybe?
    I know, i just wanted too be part of the inevitable dumpster fire too...
    @jugganuts said:
    Regards,
    Calin
    which is more $$$
    Yes , it s on progress for move on maximum performance on next days maximum two week. For now it s on power save mode because electricity it s very expensive , about 0.65$ per KWh and this server usage 200w on maximum performance.
    Regards,
    Calin
    Regards,
    Calin
    Given the services are not delivered as described, will you extend next invoice date to credit for the days that the service is not fully working?
    Hello @yoursunny unfortunity on this type of service no , in the next days and IPv6 will work, unfortunately it's the problem with the routing that I don't understand exactly why it's happening
    Regards,
    Calin
    Regards,
    Calin
    I need port 443 so that I can request TLS certificates with ACME client.
    IPv6 routing not working means the service is not usable to me.
    You should not have delivered the service before it's fully working.
    Hence, I'm asking you to extend service time starting from the date it becomes fully working.
    If you refuse, I may be forced to ask for refund.
    Thanked by (1)RapToN
    Hello @yoursunny i m understand you problems , please open ticket on website and it s possible opened you port 443
    Regards,
    Calin
    Im gratefull that you did not accept my offer. Thank you
    Hello @emperor what do you mean?
    it means you let him down. and it was in his favor.
  • Hello neighbors! ^^ How's life going?
