@tototo said:
Now I noticed that my Tokyo $2.22 is The node is currently locked (Is this on TYOC026?)
I expect you are on TYOC007 with that $2.22 special. I have the same one and it also shows locked, but I have not seen any random shutdowns like was being discussed on TYOC026.
again
virmach tokyo ryzen ping is now DOWN
Target: *[ping]
Noticed at: 2023-05-03 16:27:38 (UTC+08:00)
Encountered errors:
Dallas: Timeout (5 sec)
Singapore: Timeout (5 sec)
Tokyo: Timeout (5 sec)
@taizi - I think you have made your point. Until VirMach sees your comments do you think there is any benefit to be gained from posting every time your VM reboots ?
@FrankZ said: @taizi - I think you have made your point. Until VirMach sees your comments do you think there is any benefit to be gained from posting every time your VM reboots ?
We could always rename the thread. "VirMach VPS Status Changes" perhaps?
I don't really know what happened to me lately, over the past 2-3 weeks I have been constantly feeling tired with some lowkey dizzy, sleeping 8-9 hours a day doesn't help, no caffeinated drinks either, I wonder whether the end of my health is nigh...
I miss the old me where I can stay up all night for VirMach's VPS deals... now I can't even stay up till 10pm
good to see you here.
i was wondering where did you go?
about health .... you sound burnt out..... too much sex i guess.
good to have you back and slowly you will get back to the norm.
seriously check yourself for vitamin deficiencies.
Hey Ehab, thanks for the comment! Nice to see you still around here too. I actually participate in online communities less the moment I realize that it is probably pointless to argue with people on the internet.
I spend time enhancing my technical skills, finishing a relatively big project in the company, traveling a bit with my loved ones, working on some pet projects with friends, doing a little bit of exercise/sports, playing board games with friends, starting to treat myself a bit better than trying to save on every little thing...
I try to focus on improving myself and enjoying real life a bit more. Ever since the pandemic is over, I just realize the world is much bigger than the screen in front of me.
Thanks cybertech, that's a very good suggestion. I just realize I haven't had any fruits for the past 2 weeks, just consumed some vitamin supplements. My health report in March actually came out to be all good, so I am really worried it is something else like a brain tumor or something...
i am going to read that more than once and will try to do myself.
maybe i just want to state it is a repetitive issue?
Why not create a thread called "Taizi VirMach Complain" and consolidate it in number, as in how many times your VM rebooted in a given time period? Much more noticable then looking through 140 pages of text, dont you think?
Or why not post the output of "last reboot" next time VirMach is here ?
can be, but since I just want to let Virmach know this is a repeating issue, and happens multiple times in a day.
and unfriendly comment can't solve the issue, isn't it?
That's all because they don't have any good deals anymore! and the service he provides is trash! but ppl buy it just because it's dirt cheap! so the end of your health is NOT nigh.
well aren't you just a big ole' bundle of sunshine.
We named it Post Trauma Covid Syndrome. You feel 100% tired and would like to sleep all day.
You were showing Hetrix alerts, right? What does your resource usage look like immediately before them?
no,it is normal
if it is OOM,solusvm panel will show as online and I can see OOM warning in VNC, but now it is just offlined, so I can't check VNC to figure out...
no,it is normal
Based on the graph above, maybe you are getting wack'd by the abuse script as 70%+ average CPU use would be above the 33% AUP limit for sustained usage.
no,it is normal
I think so too. His CPU and RAM are all at 100% so it's probably the system bringing his VPS down to reduce system load.
no,it is normal
64% are iowait,i think actual usage just 6%
and i didn't receive any abuse warning ticket
some MJJ on TYOC026 have the same issue too, early then mine
Light blue is CPU, dark blue is iowait.
Now look at the light blue graph. What do you see? It's hitting 100% often.
What are you using the VPS for?
%Cpu(s): 3.0 us, 3.9 sy, 0.0 ni, 9.9 id, 83.2 wa, 0.0 hi, 0.0 si, 0.0 st
i still thinking i only used 3-6%
i am using rclone mount+google drive, which will cause a lot iowait.
again
Target: *[ping]
Encountered errors:
virmach tokyo ryzen is now DOWN
Target: Server Agent
Noticed at: 2023-05-03 19:20:51 (UTC+08:00)
try not to shutdown challenge
Ooo! Ooo! "The Taizi Challenge - Who can predict their next downtime". We can run a pool on it.
well planned and done.
Thank you
Might I suggest Probiotics. Really helped me out when I was feeling the same.
Thank you, just happened that I have a box of it now, let me consume one pack now as well
having server monitoring software post updates to slack is overrated. Having updates posted to les is what's really needed.
Gws mate!
I'm agree with all those outdoor activities.
https://microlxc.net/
Yo symptom varies, my balls itch quite often
Ontario Dildo Inspector
no,it is normal
Wait, do you have balls?
Hmm..
