1138139141143144363
  • somiksomik OG
    edited May 2023
    @taizi said:
    i am using rclone mount+google drive, which will cause a lot iowait.
    Isn't rclone/rsync known for it's high CPU usage? Also top does not give proper cpu usage records.
    You can try to limit the rclone's cpu cycle usage with "nice" and "ionice" so it doesn't crash the VPS.
    /usr/bin/nice -n 19 /usr/bin/ionice -c2 -n7 rclone sync path1 path2
  • @skorous said:
    well aren't you just a big ole' bundle of sunshine.
    got beer ?
    but most of the time spent on files GET/PUT
    now I shutdown my application and idle the server, let's see if the issue still occurs
    rsync and rclone has a faulty wait/sleep that causes high cpu load when fetching the files. I had the same issue when i was using rsync to sync up my local raspberry pi mirror.
    Do restart your server manually once and idle it for a day or two. If it still reboots, then you know the host is at fault.
    Thanked by (1)taizi
  • JabJab Senpai
    no,it is normal
  • skorousskorous OGSenpai
    @somik said: Also top does not give proper cpu usage records.
    Am curious how you mean this?
  • @VirMach how about NYCB006R ? my VPS is STILL down and the node is STILL locked ! but you mention on the status page only : NYCB009, NYCB048, NYCB042, NYCB027
    virmach tokyo ryzen is now DOWN
    Target: Server Agent
    Noticed at: 2023-05-04 23:48:52 (UTC+08:00)
    rip
  • Hello @VirMach
    my node on NYCB048 has been down for more than 3days. Even if it will be up for one day please I have a very important data locked up in there and its actually time bound. Several tickets have been submitted with absolutely no hope. Please help
  • JabJab Senpai
    @superdelight said:
    Hello @VirMach
    Try posting in more topics, it will surely help.
    @superdelight said:
    Hello @VirMach
    yes
    Thanked by (1)superdelight
  • edited May 2023
    @superdelight Yo another soul to the dust
    This thread is a damn slaughterhouse
    How many lads have been butchered so far?
    Ontario Dildo Inspector
    127.0.0.1
  • LAXA032 is time out
  • my vm on tyoc026 shutdown itself twice recently. resource usages have been constantly monitored and nothing significant was reported.
    what could be the cause?
  • edited May 2023
    @AuroraZero said: 127.0.0.1
    @lemoncube said: what could be the cause?
    @FrankZ said: now if you could just drop the "yo".
    No way, butcher Franz, yo is Flying Chinaman's catch phrase
    You might want to consider that the VirMach related comment was left in the VirMach thread even after the member was banned because the comment made by @superdelight in this thread had nothing to do with him being banned. He was banned for spamming the same comment in seven other unrelated threads in just a few minutes. If he was not banned I would expect that the number of threads this comment was spammed to would be much higher.
    Note: Your English is getting better, now if you could just drop the "yo".
    Thanked by (2)Flying_Chinaman skorous
    Keep up the good work!
    Yo yo my man, whazzup! :p
    Back on topic, who is the member representing VirMach in LES?
    @somik said: Back on topic, who is the member representing VirMach in LES?
    @VirMach
    Yo!
  • @FrankZ said:
    @VirMach
    You guys need to fix the "Last active" bit in profile...
    Do move/delete this comment if it has been said before or posted in wrong location.
    @somik said: You guys need to fix the "Last active" bit in profile...
    I noticed it was not working as well. bumped to an admin.
    Thanked by (1)somik
  • edited May 2023
    @FrankZ said: bumped to an admin.
    Yo Mason or IncelHosting InceptionHosting
    It's rather a quite a surprise that VirmAch is not this forum's sugar daddy
  • @Flying_Chinaman said:
    Yo Mason or Incel Hosting
    remove The Yo
    Yo
    YO <<<< be gone
    @ehab said:
    remove The Yo
    Yo
    YO <<<< be gone
    Bro, don't stress. It's all good, bro.
    @ehab said:
    The way that dude brotates! Sick bro!
    Thanked by (1)ehab
  • edited May 2023
    @ehab said:
    Yo man, my balls tremble...
    Thanked by (1)ehab
    all who talk bad about the regime !
  • edited May 2023
    Thanked by (1)cold
