VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
16061636566118
  • @user123 said:
    Thanks!
    Is it the same cipher as for the instructions, but preserving the Q? (I have to admit I was confused by his description of doing the post-preservation switching).
    Shouldn't be, it'll be a cipher that takes whatever the key is
  • edited December 2024
    weird I thought it would be these codes:
    just kidding i messed up
  • @VirMach said:
    Someone's already talked about the cipher and there's only one popular cipher that specifically uses a word/phrase as the key.
    So likely the vigenere cipher
    Thanked by (1)adly
    Did I choose the wrong one?
    Thanked by (1)ariq01
    > QPDGFKWI
    > QLYDOLEZ
    > MAQOZRFC
    > DQYFGDLC
    > OLBPQHSD
    > JNQHABGD
    > WFOQUCNS
    > CNOFQTKE
    Divide the cipher block into chunks of 8, and then divide those chunks into sections of 8, minus the last chunk, it'll be 9. The code we're looking for will be in the 4th block.
    Thanked by (2)slownedstark ariq01
    Remove the plugboard entry
    Empty the plugboard.
    Thanked by (1)superman
  • @Wonder_Woman said:
    That should be
    YNQYZEOL
    IAJOGMQX
    QHCJXIGD
    QESDHNNF
    MYQOIMIP
    GQPTBMIF
    YQFUCNXG
    ZNQHFXHS
    If anyone else wants to try figuring out the key, the cipher, and then trying each of these codes after decrypting and swapping out the character you think needs replacing.
    I don't want to try. I just want to see the end of the story. B)
    Thanked by (2)Wonder_Woman sh97
    It worked! Thank you
    Thanked by (1)Wonder_Woman
    @bakageta said:
    Arg, ok, I was really holding out and not buying more stuff I don't need, but offer #997 was like hand-crafted for me. Looks like I grabbed the last one, sold out. SturdyHotpink is a fantastic generated name, this bodes well.
    That's a really good one. And it's relatively cheap since it doesn't have a bunch of disk.
    @VirMach invoice # 1664716 paid several hours ago. Still not shown on my service list. Usually it only takes several minutes.
    Just to inform you. Not that I will use it right away. Thanks.
    Edit: solved in a minute, awesome
    Thanked by (1)VirMach
    Vigenere Cipher
    Edit: Still slow but getting better WW only beat me by 7 minutes this time.
    One hour left!
    Thanked by (2)Wonder_Woman user123
  • @VirMach said:
    The first working code is in the 4th part out of six parts (if you divide them into eight per part, so the last one has nine.)
    So I've reduced 1225~ potential codes to try to a little over 200.
    ~200 is assuming that we get the key right ;)
    Thanked by (2)user123 ZA_capetown
  • with the timeline, this is becoming wargames level of 'how to win' :3
    Thanked by (1)vyas
    Oops, I forgot to add manual deals. I'm going to start working on that so by the time you guys are done you can use your codes on those instead of the automated ones. Or you can not have any codes and then look at all the deals you could have had 50% off on. I'm sure @imok will be upset (if he's even around.) Maybe everyone else will just be happy they're saving money.
  • ok i will be waiting until last minutes
  • I feel like I can't get the coupon
  • Good morning, I hope you had fun this night!
    I will eat my breakfast, do my morning things and then... won't help you as it will be too late.
    Good VirMach luck!
  • @Kris $16 Tokyo is on the site page right now
    Thanked by (1)Kris
  • FAT32FAT32 OGSenpai
    Am I blind that I cannot see what's missing :joy:
    OH WAIT.
  • Thanks, Red out.
    @animeiscool said: $16 Tokyo is on the site page right now
  • @Kris I don't get it : (
  • @Wonder_Woman since you're probably working from the top of the list, I figured I'd start at the other end. I got through the last two of the block of 8 before realizing that I'm probably missing a step because I can't think and am in sleepy monkey mode. I've been replacing the Q with A-Z (minus Q) and trying those as promo codes...but I'm missing a step before that, aren't I?
    For example, I've tried the following codes (none valid):
    Y[A-Z, except for Q]FUCNXG
    ZN[A-Z, except for Q]HFXHS
    How do I even price this one...
    1776MB RAM, 1 Core, 720GB Disk, 20TB Bandwidth, 8 IPv4, in NYC.
    Thanked by (2)sh97 localhost
    Yeah, you have to convert them first using the key. The cipher is likely the Vigenère Cipher
    Thanked by (1)user123
    $1/year recurring
    More than
  • Lots of Amsterdam in the manual deal please! And a couple of New Yorks. :-D
