VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
16465676970108
  • ok i'm workng SHCBSWQE
  • edited December 3
    ok I'll take HQMMOZGN
    [I'll take QPBKAAZO] = taken by WW
  • Wait, does that mean we're not even close?
  • FrankZFrankZ Moderator
    Thanked by (1)Wonder_Woman
  • What about the case upper lower makes difference?
  • FAT32FAT32 OGSenpai
    No
    Thanked by (1)tridinebandim
  • i hope there wasn't an issue with using the wrong variant or key mode (repeat vs automode)
    In the key? It should be the same
  • @Wonder_Woman said:
    Replace the Q with A-Z:
    KZQHGXBX
    SHCBSWQE
    QAOVGPZP
    QPBKAAZO
    URQBUWPI (trying)
    TQBCIFVR
    HQMMOZGN
    SAQTOEAE
    SAETOEAE - Q with A-Z : The promotion code entered does not exist
    VPS Discounts and Reviews | Hosting Provider Directory & Check out the latest VPS offers and reviews to help you choose the best VPS service.
  • @VirMach i (we) demand more time +10hours maybe
  • edited December 3
    TQBCIFVR (A-Z) not working.
    MY/SG & Worldwide Latency Test V3 : http://www.mywebping.com (27 February 2021 Updated)
    MY-Unifi Home SmokePing: http://smokeping.mywebping.com/smokeping/
    *AOVGPZP not working
  • @mucstudio said:
    KZQHGXBX
    SHCBSWQE
    QAOVGPZP
    QPBKAAZO
    URQBUWPI (trying)
    TQBCIFVR
    HQMMOZGN
    SAQTOEAE
    I didn't get anything either.
  • JabJab Senpai
    THIS IS NICE
    Have to go back to work now... maybe next time can try this during weekend instead so I have some time :cold_sweat:
    It was fun, just I dont have time.
  • @Jab said:
    THIS IS NICE
    That is nice!
  • I just got here and there's a wonderful POST-BF Frenzy (that I clearly have no ability to comprehend).
    What just happened? I thought we had finished the hard part and had to go away to do some real work.
    Thanked by (2)Wonder_Woman FAT32
    Thanks for your help!
    Thanked by (2)FAT32 ariq01
  • edited December 3
    I think this is where we are atm:
    KZQHGXBX
    SHCBSWQE (trying)
    QAOVGPZP
    QPBKAAZO (trying)
    URQBUWPI (trying)
    TQBCIFVR
    HQMMOZGN
    SAQTOEAE
    There was more hard part, but more hard on the manual labor side of things
    Thanked by (2)nullnothere adly
  • I'm trying KZQHGXBX
  • SHCBSW[A-Z]E Not working
  • Based on @VirMach 's reaction, I suspect we've still got the wrong codes to try
    Thanked by (1)tulipyun
    edited December 3
    @Wonder_Woman said:
    May I know if you're removing the Q or not removing it from the alphabet, and are you applying it to the entire block, or just that chunk?
    I am converting the codes using the presumed key without any changes, and then taking out the letter that would be where the Q was after. Is that incorrect?
    I believe this > @Wonder_Woman said:
    @ZA_capetown said:
    @VirMach said:
    @Wonder_Woman said:
    Okay, if the key is NORTH, then
    LZ[A-Z]FSRAU
    PTWAPT[A-Z]K
    [A-Z]QJCKUPK
    [A-Z]REMOGAR
    VF[A-Z]BUVPI
    T[A-Z]YAUZUO
    F[A-Z]SGLUQT
    LW[A-Z]ASJQZ
    I suspect... he's hinting the Q should first be removed
    - then decode it
    • then where the Q was/position of the Q we do the testing adding back a letter?
    @Wonder_Woman
    That's what it's sounding like
    How was this addressed:
    @user123 said:
    @Wonder_Woman said:
    Everybody's giving up?
    Still trying, but will probably need to soon. I can't even figure out how to exclude a specific letter from decoding, and then reinsert it without doing it on paper by hand. It's already late and I still have a lot of work left to do before I can sleep. :'(
    And did I say anything on how to address or not address this issue? At this point I'm just trying to figure out if I said something I shouldn't have said in a bad way. I hope that makes sense. I'm still trying to not spell it out just in case we go into overtime once I determine whether or not that's fair.
    @ZA_capetown said:
    @VirMach said:
    LZ[A-Z]FSRAU
    PTWAPT[A-Z]K
    [A-Z]QJCKUPK
    [A-Z]REMOGAR
    VF[A-Z]BUVPI
    T[A-Z]YAUZUO
    F[A-Z]SGLUQT
    LW[A-Z]ASJQZ
    - then decode it
    @Wonder_Woman
    This was your further explanation:
    So to explain what the missing letter means, as I don't want you guys to be confused by the wording, it means you will exclude that letter from the decoding. Let's say you think it's the letter "A" you would exclude that from decoding, and therefore it remains as "A" after decoding. And then it gets replaced after decoding (all A's in this specific example only, will get replaced with one other letter, from B to Z. This takes some bruteforcing which is why I said you guys should work together.
  • HqMMOZGN not working X
  • edited December 3
    you're able to remove it from the alphabet group during the decoding part, which resulted in the second set of codes we are currently working on. this was after decoding (without any removal in that alphabet group part of the decoding process) then swapping out the letter for [A-Z] did not work
