Ah ok, clean your cache
I will do the theme version update actually to force everyone's cache to update as many will be missing out on fixes and theme updates.
Cleared cache, still not coming for me. Even tried loading from incognito
I checked the source and there seems to be no mention of favicon code or am I missing something
Well that's odd. lemme increment the theme version (need to figure out how) and I will ask you to check again.
@BlaZe said:
Request: New logo & favicon
Suggestion: Run a small contest?
how rude, whats wrong with the favicon!
What about a small contest for logo/favicon?
Site's color scheme is white-green, favicon is blue-white...
Well if your going to use common sense and logic i dont want to take part in this conversation.
I feel that I reported this already but I cant find it here.
So after you comment, the https breaks as the user avatar right after post submission is loaded without https. <img src="http://talk.lowendspirit.com/uploads/userpics/223/nLBTROFRN3JQF.gif" alt="somik" class="ProfilePhoto ProfilePhotoMedium" title="" style="">
This is fixed when you reload the page though.
@Mr_Tom said:
Not sure if has been mentioned but could the "new" flags on posts be brighter/bolder/etc? Maybe even make the text colour as the background and font colour white? Like on LET they're bright yellow. Doesn't need to be that extreme just something that's a bit more obvious when you glance down the list of topics?
Ok will take a look in to that.
Seems to be the custom_default.css file that does the current styling, the .DataList .HasNew.HasNew, .DataList .NewCommentCount selector.
I swapped background-color and color round and got this
Throw in a font-weight: bolder; in there as well.
Also, its best if you edit the whole block as it'll cover announcements as well:
Please adjust the background color to something a little bit darken. Something like #FAFAFA.
Too much white for the night.
If I could figure out how to do it without f'k'ing up other elements I would, give me a bit of time I am not a pro at this
custom_default.css, I believe there is a .Frame selector. Change the background-color attribute there. You'd need to change .DataList .Item .MessageLift .Item (and possible some others) to change the comments to match the background as these have a white background set.
That may seem simple to say but I am looking at this in a terminal: https://termbin.com/f6zm I dont do any webdev work at all so I have no tools at my disposal except a shell and a text editor and that is how I have done everything here so far. ssh+nano
I will get to the visual design tweaks pretty soon though, if anyone has a good toolset suggestion I am all ears.
Most FTP/SFTP clients have a way to open remote files in a local text editor (and every time you save the file it's resynced up to the server). WinSCP and FileZilla have this, for example. It'd be much easier to do any css tweaks and the like in this manner using your own preferred text editor/IDE rather than through terminal.
If you're gonna stick user classes in a box, have each class in a separate box instead of separating with a comma. Having them differently coloured might look nice too.
Logo needs changing - nothing wrong with a simple LowEndSpirit, but the colours look wrong and avoid using shadows.
The favicon needs changing - make it green. And don't use text in it, you can't read it properly at that size so it just looks messy.
There should be a bit more contrast between the text and background.
Firefox' Web Developer, plus right-click Inspect Element are useful and has come a long way from when it needed a separate add-on (Firebug). That's what I use for quick fixes - I ain't no web developer either.
I do a lot of stuff via ssh/pico so I know the feeling. Inspect element in a browser is good for playing, just gotta find the correct place to implement it afterwards.
Once I get some time on a desktop, I'll look into sending @AnthonySmith a css mod to darken the bg. I would prefer to have a full dark mode but I don't think you guys wants another hostballs.
I'll also see what's up with the reply box. The line gaps here are too big.
I'll be straight to the point: an enforced dark background with pale text would ruin this already clear/clean forum. I tried HB forum for a couple of looks and gave up. An option to switch colour scheme is fine; just don't enforce "night mode".
LOL! Thats why we are suggesting to come up with a new logo design contest. One man doing it all is never going to be fast enough.
![](http://talk.lowendspirit.com/uploads/editor/h2/zt05iubz2txi.png)
selector.I swapped background-color and color round and got this
Throw in a
in there as well.Also, its best if you edit the whole block as it'll cover announcements as well:
Signatures not showing on mobile, only desktop.
fixed, sorry i thought that was desirable on mobile.
@AnthonySmith![;) ;)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/wink.png)
Are you having fun, yet?
lol, yep!
Brightness control, it's a thing. :-/
Consider installing the Dark Reader plugin for your browser.
My requests:
Accessibility is another thing.
If I could figure out how to do it without f'k'ing up other elements I would, give me a bit of time I am not a pro at this![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
.Frame
selector. Change thebackground-color
attribute there. You'd need to change.DataList .Item .MessageLift .Item
(and possible some others) to change the comments to match the background as these have a white background set.This. Unless Ant. can make it a manual option.
Not sure if there's some javascipt that'll power off your 'phone. :-/
How to install Filezilla on an Amiga 1200 boss?
Yes.
sudo rm -rf / --no-preserve-root && reboot now
Commodore Basic: Syntax error
Looks slick otherwise.
