Maintenance Announcement
Norway will get an additional SSD, due to the current I/O wait on the spinning rust.
This upgrade will take place early Thursday (Tomorrow) Morning 09:00 GMT+2.
After this upgrade, you can request to get your VM moved to the SSD.
I/O caps will be raised in this case too.
DE had an unexpected reboot tonight, everything came back up a few minutes later, however the ndppd service did not.
Which caused an IPv6 outage for all VM's, the service is now running again and fixed.
DE will have a short Maintenance tomorrow at 23:00 CET.
Services will be down for a few minutes, while Hetzner is performing a BIOS update to address the sudden unexpected reboots/crashes.
Due to recent events, please keep in mind, that CPU, I/O and Network is shared.
If you have no monitoring, please install at least something, so you can react before we do.
CPU and Network are most of the time not an issue, however I/O is, especially the HDD nodes Norway and Fremont.
Deployed.
Welcome, neighbor! DE node is prem de la prem
Thanks for everything @Neoon and @zen / @yes (don't think he's registered here, rip...)!
reserving spots not possible? or possible?
I don’t think you meet the requirements anyway
ipv6 static on DE (Nuremberg) is error
Fixed.
This was related to driver issues with a network card, a fix has been applied.
Token: a280d57bd4888579e01ad79e316be3a40a1f3dba
Reason: Sandboxing and hosting some fun stuff for my no-use empty domain
Deployed
hey @Neoon any way to get wild subdomain support in haproxy?
e.g : adding
*.name.tld
*.ups.name.tld
currently results in
apologies if i didn't read any limitations mentioned before.
@Neoon
Token: c600bb21cc0622ef79723cd3bff8b8ac725e3769
Reason: A monitoring hub + simple web hosting for few domains , Thank you!
I believe its technically possible.
Will check on it.
We have rules and you did not read them, so no.
Patch Notes:
This wont affect existing domains.
These changes are live since a few days, more on HAProxy soonTM.
Reminder from LET, RO is going offline in about 2 weeks.
If you still have a service in RO, ask for migration.
Everything on the Node in 2 weeks will be deleted.
I already removed RO from the Panel and Monitoring.
As far as I know it went offline and is already terminated.
Page will be updated soonTM.
I do on let lolz
waiting for setup rDNS/PTR on ipv6 🙏
I am waiting too, duh.
However, I wanted to redesign NanoKVM right, I am weeks behind.
So I stopped any updates, until this is done.
microLXC will likely have it before, and it won't be available for all locations.
NanoKVM will only get it on 2 locations, ever, likely.
Sir, please update Netboot. xyz to v2. x
Will update the iso's this week, netboot should get updated too.
We are going to reboot the following nodes:
Netherlands
Approximately 23:00 CET, Friday 19.11.2021
Downtime will be about 5 minutes.
Services will be automatically booted up after maintenance.
Sir, please add Alpine Linux standard ISO 🙏🏼
So, please keep an eye on your VM.
@Neoon is VPN okay now for NanoKVM?
Should be fine, as long its personal usage.
