@Advin said:
ee1074d5ff673b3413a9993eaf9553f841b8ccd0
Interested in playing around with it. I'll most likely be running a couple of very small websites, and maybe also running an uptime monitor along with it
maybe Neoon has something from advinservers and him reading this is like :
Haha To be honest, I'm mostly just curious on how NanoKVM works and what I can do with one of the smaller instances. I requested their lowest plan, the 256MB one, so I'm curious on how it would handle a couple of small websites/uptime monitoring If my request does get denied, that's understandable since there's probably someone who needs it more than I do
Deployed, nah its fine.
@shallow said: @Neoon how long have you been giving these out for now? Regardless, kudos.
On Wednesday 6th of July at 11:00 UTC+3 / CEST, Network gear will be upgraded in Fremont.
The estimated downtime is a maximum of 2 hours, but we expect most servers to be online much faster.
The Reason for this, the Node is currently limited to 100Mbit, each VM to 50Mbit, after this upgrade, the Node will have full Gigabit connectivity, which means each VM will be upgraded to 150Mbit/sec after the Maintenance shortly.
Proxmox 6.4 is going EOL on 31.07.2022.
We still got 2 Nodes, NO and FM running with Proxmox 6.
Hence we need to upgrade them to Proxmox 7 until the end of the month.
I am planning upgrading booth Nodes on Tuesday, 19.07 at around 22:00 CET.
Estimated downtime 30-60 minutes, usually it goes quicker.
No plans for DE, despite its still up and running, since I am still unsure about its future.
My server's back up but IPv6 seems to be broken:
tracepath6 2620:fe::10
1?: [LOCALHOST] 0.021ms pmtu 1500
1: 2604:a100:100:2::1 0.206ms
1: 2604:a100:100:2::1 0.200ms
2: no reply
3: no reply
4: no reply
^C
2: no reply
3: no reply
4: no reply
^C
...or are they still doing maintenance?
The Maintenance only took 5 minutes, but yea from the looks of it IPv6 died.
I have forwarded the issue, they should take a look shortly.
Maintenance done, took a bit longer due to spinning rust.
Our ISP (Internet Service Provider) is performing a maintenance on its infrastructure in the interval below:
Window Start Time: Thursday, August 4, 2022 23:00 (UTC-0700)
Window End Time: Friday, August 5, 2022 02:00 (UTC-0700)
Expected Impact: < 1 hour
Reason: Switch software upgrade to enhance security and stability
I plan to use my requested NanoKVM instance to test some small Machine Learning Models for a purpose of Academic. These Models have very low bandwidth and system requirements, so I am confident that they should not negatively impact other tenants on my node. Thank you for offering this service!
Since 2018.
Proxmox 6 is going EOL soon, end of next month.
We still got 2 Nodes running Proxmox 6, FM and NO.
NL2 already runs with Proxmox 7.
I have to upgrade these by end of next month.
I will announce the the Maintenance windows soon.
very nice
Should be resolved.
Looks good. Thanks a bunch!
If someone wants the Uplink Speed upgraded to 150Mbit lemme know.
Sadly Proxmox is not making it easy.
DE node status
unknown🥺I already said, no guarantees, if you keep your vm on this node.
Everyone who wanted got a migration.
You should apply as soon as possible while Neoon can arrange other region for you, otherwise there may be one area left to choose from or even none.
Kinda but most of the time, when everything is out of stock on the page, the nodes still have enough memory and disk free to relocate a few vms.
Plus, some rumors say, they might be a new Node soon.
Token
73aff7499a532d11ccee5ac64a8663ccb238eb67
@Neoon could you help me start?
thank you very very very very very very very very very very very very very very very very very very very much
Yes, you can start by reading the rules
Fresh from the Mailbox (Fremont):
So how can I get free kvm
no
Congratulations on your first post!
$7
blog | exploring visually |
DE node
Token: 1d39894740497ed302e4a05f25ec5e6cdc4915ab
Can none of you guys read instructions?
Not connected, error: No such file or directoryFree NAT KVM | Free NAT LXC
