@Calin said:
2 TB bandwidth with 1 GBps speed/month (if the limit is exceeded, it is limited to 100 mbit/s unlimited until the following month)
Hello calin
After 2TB is exhausted, what is the limit per month @ 100mbit/s?
Hello @hotsnow
yes, I have seen the word unlimited.
but wanted to double confirm before exceeding bandwidth limit and getting into some unknown troubles may be
That's why I had tagged @Calin
Well, I switched to a different method:
I installed WireGuard client on the LowEndSeedbox, with AllowedIPs set to the subnet of my other WireGuard clients.
Firewall allows accessing qBittorrent WebUI and Rclone HTTP server only on the WireGuard interface.
I can operate qBittorrent and stream TV episodes on my other WireGuard clients.
Traffic is still encrypted but there's no TLS involved.
What were you originally trying to do ?
Caddy on IPv6 port 443, with HTTP Basic auth.
@Andrews said:
maybe the most complicated setup on the earth
you know, when each episode of your favorite soap opera costs you so much effort to get it... than it tastes much better
I access PulsedMedia seedbox via Caddy reverse proxy on WireGuard server.
It's for a different reason: getting around network congestion and lack of TCP BBR.
Why not just get a seedbox provider that doesn’t have horrible congestion?
iHostART €5.50 for 50GB
AlexHost €11.88 for 10GB
PulsedMedia €18 for 450GB
IncogNet $25 for 20GB
BuyVM $57 for 256GB
I usually download MeGusta content that is 600MB for a double-length 80min episode.
However, some content (e.g. PilotsEye) is only available in bigger files, up to 18GB for an episode.
Hence, I want at least 30GB disk.
PulsedMedia is increasing to €81, so I'm switching to iHostART.
BuyVM $57 for 256GB
LowEndSeedbox is fast at the moment.
I set qBittorrent limits to 5MB/s upload, 5MB/s download, 100 connections, 8 upload slots.
Within the same duration on the same private tracker, it's getting higher ratio than PulsedMedia.
Once all these 200+ slots are filled, I expect a significant performance drop.
Disk bandwidth is shared after all.
The server has 4TB disks so there are 80 slots per disk.
Disk bandwidth is 80MB/s so each slot gets average 1MB/s.
limiting factor here will not be a hard disk transfer rate (that mentioned 80MB/s) but number of IOPS these disks are able to provide
Hello @hotsnow done , it s delivery
Hello @yoursunny very beautiful projecti ideea on this cheap VPS!
Regards,
Calin
got it, but seems no IPv6 in vps, and can't find it in email or WHMCS, could you please help check it?
and when the FREE RAM can be added? thanks
Hello @hotsnow
Invoice #681
Thank you!
Why?
Pull outs in mud
Why?
Invoice #683
thanks
Invoice #685
thanks
Why not oracle free tier ? (Zurich)
Why?
This reminds me of the Wishosting nat box that has ended.
Oracle is not DMCA ignored.
Apparently Zurich location is. I’ve been using public torrents since a few months now.
Why?
Is it still available? @Calin
https://i.ibb.co/bHcRZnz/image.png
Invoice #689 - had to give it a go..
Syuh - sftp, rsync & rclone accessible storage from 50GB to TBs.
Hello @Calin
Node seems to be offline?
I am not even able to ping it
https://i.ibb.co/hCpgCZ5/image.png
Yup seems down
I don't know if you solved this yet, but it's most likely running out of memory. GB5 can't run on 512MB of memory.
If it has a SWAP file by default, and it's defaulting to SWAP on those disk speeds, I can see why it would crash 🙈
Hello , done now working
Regards,
Calin
makes sense. Here is the YABS after extra memory was added.
Why?
Could you check invoice #689? I've paid it, but it's still showing as unpaid for a while.
edit: marked as paid now, just waiting on the service!
@Calin may I ask when the IPv6 can working? thanks
if IPv6 doesn t work by day 89 , we can all demand refounds
VPS is up and ready. would like to have those extra 384 MB RAM. Invoice #686
