iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
1235719
  • CalinCalin Hosting Provider
    Hello @hotsnow done , it s delivery
    Hello @yoursunny very beautiful projecti ideea on this cheap VPS!
    Regards,
    Calin
  • edited November 2022
    got it, but seems no IPv6 in vps, and can't find it in email or WHMCS, could you please help check it?
    and when the FREE RAM can be added? thanks =)
    Thanked by (1)Calin
  • @hotsnow said:
    @adwsislife said:
    @Calin said:
    2 TB bandwidth with 1 GBps speed/month (if the limit is exceeded, it is limited to 100 mbit/s unlimited until the following month)
    Hello calin
    After 2TB is exhausted, what is the limit per month @ 100mbit/s?
    it is limited to 100 mbit/s unlimited until the following month :)
    Hello @hotsnow
    yes, I have seen the word unlimited.
    but wanted to double confirm before exceeding bandwidth limit and getting into some unknown troubles may be :)
    That's why I had tagged @Calin
    Thanked by (2)hotsnow Calin
  • Invoice #681
    Thank you!
  • @yoursunny said:
    Well, I switched to a different method:
    1. I installed WireGuard client on the LowEndSeedbox, with AllowedIPs set to the subnet of my other WireGuard clients.
    2. Firewall allows accessing qBittorrent WebUI and Rclone HTTP server only on the WireGuard interface.
    3. I can operate qBittorrent and stream TV episodes on my other WireGuard clients.
    Traffic is still encrypted but there's no TLS involved.
    What were you originally trying to do ?
    Why?
    maybe the most complicated setup on the earth
    you know, when each episode of your favorite soap opera costs you so much effort to get it... than it tastes much better :D
    Thanked by (2)yoursunny Mason
    Pull outs in mud
    Why?
    Caddy on IPv6 port 443, with HTTP Basic auth.
    I access PulsedMedia seedbox via Caddy reverse proxy on WireGuard server.
    It's for a different reason: getting around network congestion and lack of TCP BBR.
    Thanked by (1)jmaxwell
    HostBrr aff best VPS.
  • Invoice #683
    thanks
  • Invoice #685
    thanks
    Why not just get a seedbox provider that doesn’t have horrible congestion?
    • iHostART €5.50 for 50GB
    • AlexHost €11.88 for 10GB
    • PulsedMedia €18 for 450GB
    • IncogNet $25 for 20GB
    • BuyVM $57 for 256GB
    I usually download MeGusta content that is 600MB for a double-length 80min episode.
    However, some content (e.g. PilotsEye) is only available in bigger files, up to 18GB for an episode.
    Hence, I want at least 30GB disk.
    PulsedMedia is increasing to €81, so I'm switching to iHostART.
    Why not oracle free tier ? (Zurich)
    Why?
  • This reminds me of the Wishosting nat box that has ended.
    Oracle is not DMCA ignored.
    Apparently Zurich location is. I’ve been using public torrents since a few months now.
    Why?
  • Is it still available? @Calin
  • LowEndSeedbox is fast at the moment.
    I set qBittorrent limits to 5MB/s upload, 5MB/s download, 100 connections, 8 upload slots.
    Within the same duration on the same private tracker, it's getting higher ratio than PulsedMedia.
    Once all these 200+ slots are filled, I expect a significant performance drop.
    Disk bandwidth is shared after all.
    The server has 4TB disks so there are 80 slots per disk.
    Disk bandwidth is 80MB/s so each slot gets average 1MB/s.
    limiting factor here will not be a hard disk transfer rate (that mentioned 80MB/s) but number of IOPS these disks are able to provide
    Invoice #689 - had to give it a go..
    Syuh - sftp, rsync & rclone accessible storage from 50GB to TBs.
    Hello @Calin
    Node seems to be offline?
    I am not even able to ping it :(
    https://i.ibb.co/hCpgCZ5/image.png
  • @adwsislife said:
    Hello @Calin
    Yup seems down
  • AdvinAdvin Hosting Provider
    @jmaxwell said:
    Server goes unreachable while running GB5 test.
    # Yet-Another-Bench-Script #
    # v2022-08-20 #
    Mon Nov 7 04:31:26 EST 2022
    Uptime : 0 days, 13 hours, 24 minutes
    Processor : Intel(R) Xeon(R) CPU E5-2450L 0 @ 1.80GHz
    CPU cores : 1 @ 1200.000 MHz
    AES-NI : � Enabled
    VM-x/AMD-V : � Enabled
    RAM : 512.0 MiB
    Swap : 0.0 KiB
    Disk : 50.1 GiB
    Distro : Ubuntu 20.04.5 LTS
    Kernel : 5.4.0
    Read | 954.00 KB/s (238) | 7.74 MB/s (121)
    Write | 986.00 KB/s (246) | 8.16 MB/s (127)
    Total | 1.94 MB/s (484) | 15.90 MB/s (248)
    Read | 6.38 MB/s (12) | 6.92 MB/s (6)
    Write | 7.14 MB/s (13) | 7.34 MB/s (7)
    Total | 13.52 MB/s (25) | 14.26 MB/s (13)
    Clouvider | London, UK (10G) | 34.1 Mbits/sec | 480 Mbits/sec
    Online.net | Paris, FR (10G) | 498 Mbits/sec | 800 Mbits/sec
    Hybula | The Netherlands (40G) | 526 Mbits/sec | 867 Mbits/sec
    Uztelecom | Tashkent, UZ (10G) | 456 Mbits/sec | 365 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 393 Mbits/sec | 317 Mbits/sec
    Clouvider | Dallas, TX, US (10G) | 343 Mbits/sec | 154 Mbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 257 Mbits/sec | 183 Mbits/sec
    I don't know if you solved this yet, but it's most likely running out of memory. GB5 can't run on 512MB of memory.
    If it has a SWAP file by default, and it's defaulting to SWAP on those disk speeds, I can see why it would crash 🙈
    Hello , done now working
    Regards,
    Calin
  • makes sense. Here is the YABS after extra memory was added.
    Tue Nov  8 05:31:13 EST 2022
    Uptime     : 0 days, 14 hours, 41 minutes
    CPU cores  : 1 @ 1290.000 MHz
    RAM        : 896.0 MiB
    Swap       : 0.0 KiB
    Disk       : 50.1 GiB
    Kernel     : 5.4.0
    Read       | 791.00 KB/s    (197) | 8.15 MB/s      (127)
    Write      | 828.00 KB/s    (207) | 8.59 MB/s      (134)
    Total      | 1.61 MB/s      (404) | 16.74 MB/s     (261)
    Read       | 10.09 MB/s      (19) | 9.27 MB/s        (9)
    Write      | 11.26 MB/s      (21) | 10.45 MB/s      (10)
    Total      | 21.35 MB/s      (40) | 19.73 MB/s      (19)
    Clouvider       | London, UK (10G)          | 43.5 Mbits/sec  | 329 Mbits/sec
    Online.net      | Paris, FR (10G)           | 496 Mbits/sec   | 596 Mbits/sec
    Hybula          | The Netherlands (40G)     | 491 Mbits/sec   | 897 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 375 Mbits/sec   | 388 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 367 Mbits/sec   | 229 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 343 Mbits/sec   | 164 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 353 Mbits/sec   | 161 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 480
    Multi Core      | 483
    Full Test       | https://browser.geekbench.com/v5/cpu/18505940
    Why?
    Regards,
    Calin
    Could you check invoice #689? I've paid it, but it's still showing as unpaid for a while.
    edit: marked as paid now, just waiting on the service!
  • @Calin may I ask when the IPv6 can working? thanks
    if IPv6 doesn t work by day 89 , we can all demand refounds
    Thanked by (1)hotsnow
  • VPS is up and ready. would like to have those extra 384 MB RAM. Invoice #686
