May I know if you're removing the Q or not removing it from the alphabet, and are you applying it to the entire block, or just that chunk?
I am converting the codes using the presumed key without any changes, and then taking out the letter that would be where the Q was after. Is that incorrect?
i tried this
The promotion code entered does not exist
[A-Z]I’m a simple man I see gifs, I press thanks
This monkey is starting at the bottom.
New ones to try, let's divide and conquer:
LZ[A-Z]FSRAU
PTWAPT[A-Z]K
[A-Z]QJCKUPK
[A-Z]REMOGAR
VF[A-Z]BUVPI
T[A-Z]YAUZUO
F[A-Z]SGLUQT
LW[A-Z]ASJQZ
I'll take the first one
key = NORTH ?
Virm Deals
wget -qO- 103.179.44.36:5004
with # being [A-Z]?
I tried my python code an hour ago but no luck
Virm Deals
I am taking this
#ApesTogetherStrong
everyone's coming together
Can a few people come and divide the test, I will test > LZ[A-Z]FSRAU
VPS Discounts and Reviews | Hosting Provider Directory & Check out the latest VPS offers and reviews to help you choose the best VPS service.
I'll take the PTWAPT[AZ]K
It's not LZ[A-Z]FSRAU...
I'll take T[A-Z]YAUZUO
Trying VF[A-Z]BUVPI now
It's not the last one, LW_ASJQZ. Halfway through F_SGLUQT.
Tried and no go. F[A-Z]SGLUQT
It is not
*QJCKUPK
F[A-Z]SGLUQT
[A-Z] does not exist
Night guys.
Summary:
tried
Trying
[A-Z]REMOGAR
now.@Kris Good night
Plan #1013 is the lowest price I've seen so far for a plan.
I felt like a hacker.
@FAT32 is working on [A-Z]REMOGAR
I feel more like this
