@VirMach said: Now some further clarifications as I'm sure there will be questions:
This is what it would have been and not what's currently displayed on the website. It means I'll be processing the math in the same way or close to the same way the system would be churning them out. They will be closer to the manual deals since they're being done manually. My brain has a good idea of exactly what I would have put for your node, so it won't just be resources divided by whatever quantity, it may receive multipliers if for example my brain says that would have been a better fit than smaller plans.
It is based on the node you landed on so I'll be processing them in batches with matching nodes. This means if someone landed on the same exact node as you, both of you will be getting the same specifications.
For "if it's lower" if any portion of it is higher, you'll be getting the difference added for that specification, not just that if it's lower at all or generally then it'll stay the same.
If there's any disputes on the fairness of what was generated, and every person who landed on the same node agrees (it could just be you) I'll allow you to request I look at it again. The request may be accepted or declined, and if it's accepted, I'll look through logs specifically for the most recent suggested plan for that node instead and using that, whether it's lower or higher.
🤡 "The tags provided to users are worthless permanent labels~ accept them or leave!" 🤡
@VirMach - you noticed.
I thought I would keep quiet so I did not jinx anything (or bias you). As for the initial result and then the 'upgrade', I think you were generous and certainly did your best. Now I have 11 vms, 10 in Amsterdam so expect a lot of moving / changes to actually pay for these mystery boxes
+ADD
BTW one panel says FFME002.VIRM.AC other says AMSD018 - so is this the move to FF done (would have selected FF if it had been available anyway)?
"Friendly" names are only updated in billing panel, the SolusVM still have old Frankfurt names as this would potentially break a lot of stuff.
It's in Amsterdam, there are no servers in Frankfurt, there is no Frankfurt - all servers were physically driven by VirMach himself across the border.
---------------------------------- nws.sh ---------------------------------
A simple script to bench network performance using speedtest-cli
Version : v2024.12.20
Global Speedtest : wget -qO- nws.sh | bash
Region Speedtest : wget -qO- nws.sh | bash -s -- -r
Basic System Info
CPU Model : AMD Ryzen 9 3900X 12-Core Processor
CPU Cores : 4 @ 3799.996 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 237.1 GB (35.3 GB Used)
Total RAM : 3.3 GB (730.6 MB Used)
Total Swap : 2.0 GB (3.5 MB Used)
System uptime : 0 days, 3 hour 6 min
Load average : 0.08, 0.02, 0.01
OS : Rocky Linux release 9.5 (Blue Onyx)
Arch : x86_64 (64 Bit)
Kernel : 5.14.0-503.19.1.el9_5.x86_64
Virtualization : KVM
TCP Control : cubic
Basic Network Info
Primary Network : IPv6
IPv6 Access : ✔ Online
IPv4 Access : ✔ Online
ISP : Hurricane Electric LLC
ASN : AS6939 Hurricane Electric LLC
ASN (IPv4) : AS4213 Krypt Technologies
Host : Hurricane Electric LLC
Location (IPv4) : San Jose, California, US
Speedtest.net (Region: NORTH AMERICA)
Location Latency Loss DL Speed UP Speed Server
ISP: Evocative-global
Nearest 13.93 ms 0.0% 869.19 Mbps 790.60 Mbps KamaTera, Inc. - Cheney, KS
Vancouver, BC 23.92 ms N/A 867.75 Mbps 496.10 Mbps TELUS - Vancouver, BC
Calgary, AB 34.40 ms N/A 901.21 Mbps 654.16 Mbps Shaw Communications - Calgary, AB
Winnipeg, MB 52.08 ms 0.0% 895.79 Mbps 650.99 Mbps Voyageur Internet - Winnipeg, MB
Toronto, ON 62.45 ms 0.0% 881.06 Mbps 243.72 Mbps Bell Canada - Toronto, ON
Montreal, QC 69.62 ms 0.0% 881.24 Mbps 279.05 Mbps Rogers Wireless - Montréal, QC
New York, NY 63.17 ms 0.0% 887.23 Mbps 645.15 Mbps Surfshark Ltd - New York, NY
Ashburn, VA 64.17 ms 0.0% 897.93 Mbps 665.04 Mbps Rackdog - Ashburn, VA
Charlotte, NC 62.46 ms N/A 871.61 Mbps 285.49 Mbps Windstream - Charlotte, NC
Atlanta, GA 55.18 ms 0.0% 866.02 Mbps 311.62 Mbps i3D.net - Atlanta, GA
Miami, FL 69.14 ms 0.0% 875.38 Mbps 240.84 Mbps ReliableSite Hosting - Miami, FL
Dallas, TX 39.81 ms 0.0% 866.88 Mbps 386.18 Mbps i3D.net - Dallas, TX
Houston, TX 43.45 ms N/A 864.84 Mbps 337.80 Mbps Comcast - Houston, TX
Kansas, MO 46.07 ms 0.0% 887.05 Mbps 494.05 Mbps Nocix - Kansas City, MO
Minneapolis, MN 45.73 ms 0.0% 901.69 Mbps 451.02 Mbps US Internet - Minneapolis, MN
Chicago, IL 47.09 ms 0.0% 877.17 Mbps 347.72 Mbps Hivelocity - Chicago, IL
Cleveland, OH 64.88 ms N/A 870.33 Mbps 272.88 Mbps Windstream - Cleveland, OH
Albuquerque, NM 35.27 ms N/A 857.48 Mbps 423.20 Mbps Comcast - Albuquerque, NM
Denver, CO 32.48 ms 0.0% 898.30 Mbps 377.05 Mbps T-Mobile Fiber | Intrepid - Denver, CO
Portland, OR 16.60 ms N/A 895.44 Mbps 733.08 Mbps CenturyLink - Portland, OR
Las Vegas, NV 14.80 ms N/A 885.70 Mbps 736.38 Mbps Dish Wireless - Las Vegas, NV
Salt Lake, UT 23.73 ms N/A 862.67 Mbps 562.55 Mbps Novva Data Centers - Salt Lake City, UT
Phoenix, AZ 19.39 ms 0.0% 887.56 Mbps 559.28 Mbps Xiber LLC - Phoenix, AZ
Los Angeles, CA 8.97 ms 0.0% 855.96 Mbps 777.57 Mbps ReliableSite Hosting - Los Angeles, CA
San Jose, CA 2.16 ms 0.0% 857.17 Mbps 828.72 Mbps Misaka Network, Inc. - San Jose, CA
Spokane, WA 31.60 ms 0.0% 862.90 Mbps 352.50 Mbps Crunchbits - Spokane, WA
Seattle, WA 19.92 ms 0.0% 870.62 Mbps 555.12 Mbps Misaka Network, Inc. - Seattle, WA
Hermosillo, MX 53.98 ms 0.0% 874.11 Mbps 295.76 Mbps Megacable - Hermosillo
Guadalajara, MX 66.61 ms 0.0% 693.75 Mbps 368.81 Mbps AT&T México - Guadalajara
Mexico City, MX 47.07 ms N/A 885.19 Mbps 353.08 Mbps INFINITUM - Ciudad de México
Avg DL Speed : 871.64 Mbps
Avg UL Speed : 482.52 Mbps
Total DL Data : 32.58 GB
Total UL Data : 18.98 GB
Total Data : 51.56 GB
Duration : 12 min 15 sec
System Time : 29/12/2024 - 04:51:35 CST
Total Script Runs : 93536
Result : https://result.nws.sh/r/1735469401_IZQBG1_NA.txt
OFFER #2004
$6.95 PER YEAR
VIRT KVM
RYZEN SKU# V01-XD
1024MB DDR4 RAM
1 Core CPU vCORE
20GB SSD (NVMe)
1536GB BANDWIDTH
2 IPv4
Must be popular as this has gone up twice. Now at $7.23
I think the IP pricing portion of the code is broken, I've seen a few of them here and there that are priced pretty nonsensically but it's hard to know for sure since a lot of these prices don't make a lot of sense.
@msatt said: BTW one panel says FFME002.VIRM.AC other says AMSD018 - so is this the move to FF done (would have selected FF if it had been available anyway)?
I'll go through and update the names on the other control panel soon, I might clear those out completely since so many people look at those and we don't actually use them anymore (the "friendly" name on SolusVM.)
Is any IP space still HE TunnelBroker capable?
My recent purchase in San Jose IPv4 91.186.xxx.xx had no issue with HE TunnelBroker.
I have seen issues with the Quadranet IPv4 and HE tunnels, but Vir uses different IP blocks besides Quadranet in non Quadranet locations.
EDIT: Candle #4 is up. Which has been termed as Wild
And "wild" means possibility of getting no gift/small gift.
But I'm thinking there is probably a flip side to that too, for a few lucky ones.
But I really don't know any more that anyone else. So you probably should not listen to anything I have said above.
@FrankZ said: But I'm thinking there is probably a flip side to that too, for a few lucky ones.
@VirMach
what's up with the ssh port or is there something im missing?
i'm trying to change the default port, system check shows me that its successful. but then i can't log in using new ssh port. it also happened to another virmach vps(ubuntu), although that turned out ok in the end (im not sure how it did, checked back hours later and it let me in using the new port). and there're a few more vps which i haven't looked at yet.
this is on alma BTW. im posting here since the BF/flash deal thread is currently closed.
@thelocalhost said: @VirMach
Make sure /etc/selinux/config shows SELINUX=disabled or selinux will keep sshd from starting if it is not on the default port.
There are other ways to fix it and keep running selinux and ssh on a non default port, but I expect you will run into other issues if it is not disabled, so better to just disable it.
those with unused "One More Idler " must be smiling
OFFER #2004 comes to under 6 US dollar after the 25 percent discount
blog | exploring visually |
So I am writing that it is only $0.25 and then it goes up again. Think I'll buy another Mystery Box instead.
Fuck me, that Amsterdam with 4 IPs Mystery Candle Box would be amazing.
Why I was nice to VirMach and decided to skip it?!
God damn, life is unfair
/s
+ADD
I'm still slightly hopeful that a peachy one will appear that uses up my ~$13 Vir-balance.
I just bought my first VirMach VPS! 😁 (also my first post on LES lol)
Congratulations.. to many more
Thank you!!
Welcome welcome welcome! Would you mind sharing the location + price?
VirMach Mystery Box Candle #3 San Jose
YABS
Speedtest
Basic System Info
CPU Cache : 512 KB
AES-NI : ✔ Enabled
TCP Control : cubic
Basic Network Info
HE TunnelBroker is no longer fragrant.
Nowadays we tunnel from our own router in a nearby IXP or use https://bgptunnel.com/ for transit.
No hostname available. affbrr
Thank you!!
It is in Los Angeles, CA for $7.68 and it came with 2 IPv4's! Great deal!
Are you sure you are not Virmach.....
i knew it if its complicated and if i get ams it wil get more complicated... and didnt order now you can give them a big vps to make me regret...
edit: i should comment after reading all comments
lets see how wild this candle
@VirMach
i hope it comes and lives with its name
Disappears like Virmach, writes like Virmach...
But he's Mexican.
Definitely not Virmach.
@FrankZ you are Mexican right? Am I getting confused?
Yes, I am Mexican, I am also other things.
[but definitely not VirMach]
You won't get me with that!
That's because you are too smart for me.
and for Ubuntu it's probably the stupid systemd thing and editing ssh config files makes no difference
https://serverfault.com/a/1159600
or you mask/disable the ssh.socket and restore ssh.service to have it the old, good way.
https://askubuntu.com/a/1439482
will look at that. thanks
That's what @virmach would say.
But one making things simple and easily understood as always, while the other ...
Virmach Deals
